Motor mounts cause vibration when reverse
Old Jun 25, 2015 | 02:49 PM
Jaxson75's Avatar
I've noticed a vibration when i pull out of my driveway and when I drive and hit a bump i get a rattle like the exhaust is loose, but I install all new exhaust from downpipe to muffler. I know everything is on tight. what I also hear is humming noise coming from the drive side, i replaced the wheel hub and bearing. This sound like the mounts on the driver side, if so, should i just change all of them...your thoughts.
Old Jun 25, 2015 | 03:07 PM
jakermeister's Avatar
the back mount is a PITA!!!!!!!!! just warning you. Even when I had my transmission out it was a pain.
Old Jun 26, 2015 | 06:16 AM
slatermvp's Avatar
definitely agree the one in the back sucks to put in.
Old Jun 26, 2015 | 07:21 PM
Jaxson75's Avatar
So i should just replace all of them or just do the front and back ones?
Old Jun 27, 2015 | 05:59 AM
roach85's Avatar
Check to make sure a heat shield is not touching the exhaust, that could be the rattle.
Old Jun 27, 2015 | 04:08 PM
Jaxson75's Avatar
its a new Cat, the vibration does it more on reverse.
2StepsAhead
35
Feb 10, 2015 03:27 PM
02ES=>09RAL
Nov 2, 2014 06:50 PM
EvoDan2004
30
Sep 23, 2013 01:57 PM
Nathan0490
Lancer Troubleshooting
Mar 24, 2010 09:54 AM
Speed Element
10
Jul 8, 2008 05:03 PM
