Oil light is on when standing still
Old Mar 25, 2004 | 06:35 PM
sadude's Avatar
Hey guys
My oil light is on whenever I am standing still or idling. Doesn't matter park or any other gear.
I am currently using valvoline 5W-30 normal oil, not synthetic or anything with a STP oil filter
Does this mean my oil pump is shot? if so where is at and how do I change it?
I don't think this is a faulty sensor otherwise the sensor would be on all the time
Oh yeah the level is fine.
thanks for your help
Old Mar 25, 2004 | 06:45 PM
fkrzo's Avatar
To check if your sensor is OK you have to hook up a guage and see if your oil pressure is in check. If its your pump, you have to pull off the oil pan to get to it. I would first try changing the oil to a 10w30 and see if that remedy's the issue.
Old Mar 25, 2004 | 07:59 PM
sadude's Avatar
Changing to 10W30 shouldn't be too hard to do
How hard is it to hook up an oil pressure gauge? Any brands I should look at, I guess a-pillar here i come
Old Mar 27, 2004 | 06:11 AM
fkrzo's Avatar
Not a permanant guage, There should be a way to connect a fitting right over the oil filter (I will check where today). just watch the guage at idle and when you rev it. If it gets to low at idle then its more than likely that your oil is old and to thin or your pump is shot.
Old Mar 27, 2004 | 02:25 PM
sadude's Avatar
well my oil is like only a week old
Old Mar 27, 2004 | 06:57 PM
fkrzo's Avatar
Not meaning anything bad but are you low on oil (like a whole quart).
Old Mar 28, 2004 | 09:38 AM
sadude's Avatar
I checked my oil like on friday and it was fine, I'll check it again
can I get more info on that pressure gauge that mounts by the oil filter (?)
thanks for all of the help so far
Old Mar 29, 2004 | 09:18 AM
Kontradictions's Avatar
i would bump up your oil and see if that works. I run a 20w50, but i have a turbo. Definitly try changing the oil, if it still comes on I would get a check guage to check the pressure like what was mentioned before. An oil pressure gauge is your best friend. Comes in handy all the time! If none of that helps, then take it to the dealer...
Old Mar 29, 2004 | 02:13 PM
sadude's Avatar
yeah i was thinking of bumping up the oil to at least 10w40
also i wanna do the oil pressure gauge...simple mod but who sells the whole a-pillar pods that are swappable, i don't want to bolt on pods that i have to drill for
Old Mar 29, 2004 | 03:23 PM
fkrzo's Avatar
Lancershop, RRM and Autometer.
Old Mar 29, 2004 | 07:16 PM
sadude's Avatar
okay guys...small update
i had recently added in a bottle of some kind of oil cleaner/detergent and looks like it took care of some of the gunk that was probably effecting the oil flow
thanks for everyone's help
cal1mr
Jun 9, 2015 07:19 PM
kenshi3
Aug 19, 2012 09:51 AM
LGrady31
Oct 3, 2009 04:26 PM
GBAILEY472
10
Apr 17, 2009 10:16 AM
