What is normal oil Pressure ???
Old Mar 26, 2009 | 09:18 AM
GBAILEY472's Avatar
I recently had install a oil pressure switch, the sensor is set at 18lbs...( light goes on ) I run the car no prob, basic bolt on, Exhaust,d-pipe,intake,feul pump...etc I run the car normally... light goes on on Idle..
The stock sensor light in dash still intalled dosen't flash... after a heavy run what is the normal oil pressure on idle 600-700 rpm ?
Stock sensor set at ???
Please help
Thanks
Old Mar 26, 2009 | 09:23 AM
Rob_GPT's Avatar
I was seeing 35 psi after warmup (if i remember right) but over 100 when cold. I coudl be wrong on the warmed up pressure though. I only got to drive the car 2 times with the pressure sensor.
Old Mar 26, 2009 | 09:27 AM
1NastyMR's Avatar
Mine does that to. Under 20psi but I have a idle issue and a Tial BOV currently on stock ecu and idle drops and car sometimes turns off because of it. Normal psi should be about 30ish from what I was told at full temp. I've also been told low pressure could be a oil pump going bad or bearings
Old Mar 26, 2009 | 11:27 AM
GBAILEY472's Avatar
Bump !
Old Mar 26, 2009 | 05:19 PM
05ah8james's Avatar
I see way below 20 once the car is warm at idle. probably... 10 - 15? When cruising i see about 80. 100psi when car is cold, or romping on it.
Old Mar 26, 2009 | 05:24 PM
SWOLN's Avatar
Oil presure is a funny thing. It depends where you get the signal. It also depends on the oil weight, and the temp. The hotter and lighter oils will show a lower psi. I suppose the best way to observe it, is record the inital psi and parameters, and go from there.
Old Mar 26, 2009 | 05:35 PM
6-speed's Avatar
Well said.
My Defi oil pressure sensor is mounted on the side of the block and the pressure readings are much lower than what somebody would read if the sensor were mounted at the oil filter.
At idle my pressure can be as low as 5 psi.
Old Mar 26, 2009 | 06:06 PM
Kracka's Avatar
When fully warmed up I sit between 10-20 psi at idle and 70-80 psi at a 3k rpm cruise. This is with a Defi gauge and sensor on the oil filter housing.
Old Mar 26, 2009 | 07:47 PM
barneyb's Avatar
Anywhere between 4 (hot idle) and 150 psi (cold start and driving).
Old Apr 16, 2009 | 10:00 PM
StreetSweeperIX's Avatar
I have the defi gauge and the sensor mounted on the oil filter housing, I usually sit about 80-85 at a cruise and around a 100psi at wide open throttle. I noticed something interesting today though with the idle reading. I changed the oil and was running the longer skinnier oil filter and at idle a lot of the time psi would drop to 4 and sometimes 0 and the car would die. Today I went to the shorter fatter filter and I'm holding a more steady reading just below 20 psi at idle after the car is warmed up and the car didn't die at all.... all of which made me come to EvoM searching for how much psi I should be seeing.
Old Apr 17, 2009 | 10:16 AM
Davo's Avatar
i think oil weights with your pressure would be a bit more helpful
CaptainSquirts
Jul 5, 2016 07:43 PM
bboy_RES
28
Dec 11, 2015 05:01 AM
JTB
20
Feb 21, 2010 12:05 AM
bboy_RES
Jan 29, 2008 08:03 AM
4G63>OOOO
Dec 2, 2003 12:09 PM
