Normal Oil Pressure?
Old Jan 27, 2008 | 11:58 PM
bboy_RES's Avatar
i just installed my Defi BF Oil Pressure Gauge. i noticed when i'm idling in neutral or when i have the clutch pressed in my oil pressure is around 20 psi, sometimes lower around 10-15 psi. when i'm cruising my oil pressure is around 80 psi. are these normal readings? what should i have my warning light set to? thanks.
Old Jan 28, 2008 | 12:04 AM
moreryce's Avatar
yea sounds normal... is the 80psi when its cold? because mine normally chills around 60psi when im cruising on the freeway around 3k rpms when the engine is fully warmed up... also after some freeway driving mine goes as low as 1-5psi at idle.. lol
Old Jan 28, 2008 | 12:38 AM
bboy_RES's Avatar
well i think it's at 60-80 psi depending on what rpm's i'm at. yeah mine goes really low when i'm about to park after a little drive. thanks haha.
Old Jan 28, 2008 | 12:42 AM
Cali2MDevo8's Avatar
Registered User
DId you need to purchase a adapter to get the Defi oil pressure gauge to work on the evo?
Old Jan 28, 2008 | 01:10 AM
bboy_RES's Avatar
yeah i purchased the 42draftdesigns 1/8 bspt adapter. fits perfectly! how much were you trying to buy the stock 9 dv for? i might be selling mine soon.
Old Jan 28, 2008 | 07:51 AM
justboosted02's Avatar
mitsu manual says that you should have at least 4.2psi oil pressure at idle, anything more is just a bonus
Old Jan 28, 2008 | 08:16 AM
UT_Evo's Avatar
Yeah, at idle I was around 5-10 depending on the incline and the temp of the car, supposedly the 4g63 idles notoriously low (doesn't sound all that low, considering nothing is happening with the engine, but my Porsche idles at 30-40 psi). At freeway and full throttle etc it was between 50 and 80 usually, also depending on load, 80 seems to be common between most cars. What you need to watch for (and recording with the Defi-Link helps for this) is it dropping under load or in high speed areas (Mainly if you're track racing or autocrossing... shouldn't matter a whole lot on the street). All too many cars have had motor failures in high speed corners because the oil pump couldn't grab any oil from the pan.
I ended up setting my warning light to 8 because once the car was warm and w/ my accusump it rarely dipped under 8ish psi. Defi needs to set up a load and non-load warning... Because, IMO 8 is WAY too low if you're WOT. Best thing to do is set it to just below the lowest you've seen it idle AFTER you've checked to be sure your oil is at the "full" level and then keep an eye on it while you're under load.
Old Jan 28, 2008 | 08:30 AM
Kracka's Avatar
At 3k RPM's on the highway my Defi gauge reads 80psi and at an idle I'm between 15-20 (these values are for a fully warmed engine).
Old Jan 28, 2008 | 09:14 AM
LanEvoNine's Avatar
On cold startup idle my oil pressure hovers around 100psi... then when it is fully warm it hovers around 20 psi at idle... forgot to mention this is on a Defi BF oil pressure gauge
Old Jan 28, 2008 | 03:22 PM
dbotkin5's Avatar
That's where mine is at while idling, so sounds normal to me
Old Jan 28, 2008 | 03:32 PM
redevo21's Avatar
Yea that sounds about right.
Old Jan 28, 2008 | 03:45 PM
waitin4d's Avatar
Mine idles at 25-30 psi when cold.. but then again, I've raised my idle to 1100.
Cruising around 80mph, pressure holds around 80psi.
Old Jan 28, 2008 | 07:41 PM
6-speed's Avatar
Oil pressure readings (either at WOT or at idle) would also varies depending on where you mounted your oil pressure sensor.
It should read lower if you mounted it at the block versus at the oil filter.
Old Jan 29, 2008 | 02:12 AM
Jameson_IXMR's Avatar
Wheww. I just installed one and took it for a spin around the block and it sank really low, so I putted 5mph or less home and checked the oil level and for leaks. This thread helped alot, it should be listed in the newbie post that has all specs and limits.
Old Jan 29, 2008 | 04:13 AM
Davo's Avatar
the different bodies of oil will also play a part in giving u those numbers so to really compare you guys need to say what body of oil is being used in conjuction with pressure
having said that i sold my autometer oil pressure gauge and have yet to receive my stri unit so i can't give my numbers
my oil is 10w-40 amsoil
