Normal Oil Pressure?
Old Aug 28, 2009 | 07:54 PM
v8<turbo4's Avatar
when i am at full throttle mine will read past 100 PSI which is off the gauge is that something i should be worried about it seems like its very high if the gauge doesnt even go that far
Old Aug 29, 2009 | 06:30 AM
v8<turbo4's Avatar
bump
Old Aug 29, 2009 | 04:48 PM
03EVOGUY's Avatar
when i first start my car im at around 95psi then when its warm it will idle around 15-25psi sometimes will go as low as 10psi. yea mines does that too. when im at full boost it will go to 100psi. its all normal. evos have just have high oil pressure. my oil is also 10w-40 amsoil and a prosport gauge
Old Sep 1, 2009 | 07:27 AM
Davo's Avatar
10w-30 Amsoil
cold start is 76psi, hot idle is 14-16psi and at WOT I am just about 90-100psi
Old Sep 1, 2009 | 01:16 PM
CGroovy2k2's Avatar
Thats normal. I have the Defi Blue Racer gauge and it reads about what you have there.
Old Sep 1, 2009 | 01:28 PM
Kracka's Avatar
Oil pressure is not load-based so please stop saying X psi @ WOT. It is much more accurate to state a specific RPM.
Old Sep 1, 2009 | 01:38 PM
TalonTuner4G63's Avatar
Yes, oil pressure is rpm dependent, not load dependent.
Old Dec 24, 2010 | 02:35 PM
CJ2X's Avatar
Mine is at 120 PSI at 6000 RPM's, 90 PSI at 3000 RPM and 20 PSI at idle... Is this normal?
Old Dec 24, 2010 | 03:08 PM
barneyb's Avatar
Still normal.
Old Aug 13, 2011 | 11:47 AM
WHTEVO's Avatar
Sorry to bring an old thread back, but it seems this is a good topic. I think you all should also state whether or not you have balance shafts installed as this will cause i difference in the oil pressure readings. Will be higher when removed.
Aaron
Old Feb 22, 2012 | 03:50 PM
mouseIX's Avatar
Originally Posted by justboosted02
mitsu manual says that you should have at least 4.2psi oil pressure at idle, anything more is just a bonus
Thank you thank you thank you!! I've been searching all evening looking for this info!! you just gave me so much peace of mind !!
Old Dec 8, 2015 | 06:43 AM
Jeepyedo's Avatar
Might be off topic but obviously my PSI will be higher with a cold start, will this affect my cruising PSI at 3000RPM until my temp is up to normal?
Old Dec 10, 2015 | 10:43 AM
awhit17's Avatar
Yes, this is also a good way to see when your car is actually warmed up, since your oil pressure will be higher across the board until the oil reaches its normal operating temp
Old Dec 11, 2015 | 05:01 AM
Jeepyedo's Avatar
Good to know. Thanks
RSMike
138
Jul 20, 2025 09:19 AM
tscompusa2
1564
Sep 26, 2024 07:45 AM
MRfabolous
48
Aug 17, 2017 07:15 PM
BTR
Jul 4, 2017 05:44 PM
Epyon
Mar 30, 2016 09:36 AM
