valve adjsutment
Old Apr 20, 2016 | 09:03 PM
jimbo74's Avatar
Veteran: Air Force
valve adjsutment
how can I adjust the valves?
We did my timing belt, and it seems great, no issues, but I think it had a tick at startup that I never noticed before, if it was there at all. It did go away after a few minutes.
03 Lancer ES 4G94
Old Apr 21, 2016 | 01:34 AM
jimbo74's Avatar
Veteran: Air Force
so.... started up the car again, no issues @ all..... while doing he timing belt, we had on the right side of the car lifted up, and since the motor had to be support, we also had a cherry picker pick up the motor on that side... So I assume what happened, is that there is a unit called the Valve Lasher, and it said in extreme circumstances, it can drain the oil it usually has out, and make a bad sounding ticking that should go away after awhile... well it did go away, and we went for a test drive. hours later, when started up, quiet, just as I remembered....
Basically, I think there is no valve adjustment, those Lashers are hydraulically adjusted?
Long story short, there is no issue at all....
we actually did the timing belt TWICE! because we heard the crazy loud ticking, and thought we were off a tooth, so we took it apart to see what was up.
Old Apr 21, 2016 | 01:49 AM
jakermeister's Avatar
Yup it's normal. I was concerned about it when I did my timing belt too. It was a bit noisy for a while then it went away. I knew the engine was fine tho because I would've immediately thrown a cel, which I didn't.
Old Apr 21, 2016 | 01:59 AM
jimbo74's Avatar
Veteran: Air Force
dude, we were so scared!!!!!!!!! wasn't until we kept looking in the manual for how to adjust the lifters, that we found that lasher thing.....
fletch
Aug 11, 2005 05:55 PM
evodave
Jan 3, 2005 05:40 PM
accodata85
Apr 21, 2004 10:11 AM
OX
Nov 19, 2003 11:40 AM
