lancer
Old Nov 19, 2016 | 04:42 PM
alvie francois's Avatar
lancer
Can a 2000 Galant engine work in a 2003 Mitsubishi Lancer the Galant engine is a 2.4 the Mitsubishi Lancer is a 2.0
Old Nov 19, 2016 | 04:55 PM
jb988's Avatar
I'm pretty sure the engine in the Galante is a the engine with the 4g64 code and it has a different mount than the 2.0 and a couple of other things that would be needed for the seap. Search on here. A couple of people of done it. Not cheap or faster than just swapping in another 2.0
Old Nov 20, 2016 | 07:20 PM
what if I have the engine and transmission would that just be easier switch and would I also have to weld new engine mounts or should it line up
Old Nov 21, 2016 | 07:57 AM
jb988's Avatar
There are two more issues. From my understanding you would need the internals of your transmission and the housing of the galants and put them in there. You'd also need to custom fab. A motor mount and there was also the issue of the ecu, wiring harness, and the immobilizer that came on certain cars.
Kontradictions
Oct 26, 2002 07:06 PM
DaTenshi
Oct 3, 2002 12:19 PM
