4g94 rebuild
Old Feb 4, 2017 | 04:20 PM
LudaChrisLancer's Avatar
Unhappy 4g94 rebuild
Hey guys, I have recently rebuilt my 4g94 engine after the timing belt obliterated and caused 10 valves and 3 guides to break resulting in me purchasing a new cylinder head. I have done everything right according to the book as far as torque specs and wiring placement. When I tried to turn the engine over, i got a code corresponding to the camshaft positioning sensor. After i replaced that and made sure that each cylinder was getting enough gas from the injectors, i checked the coil packs to see if i was getting spark. Both coils work, however, the coil powering plugs 2 and 3 isn't getting power. I checked the connector wiring harness with a volt meter and I wasn't getting power. I traced the wire back to see if i missed any grounds or any connections that would effect the voltage from getting to the coil wire and I didn't see anything out of the ordinary. Not sure what to do at this point. Maybe you guys have some ideas or pointers to help me get my car started again. I miss my baby!!
marcouxa1
Lancer Aftermarket Forced Induction Tech
55
Jul 31, 2025 08:23 AM
LudaChrisLancer
Lancer How Tos / Installations
Feb 4, 2017 04:13 PM
NoClanSWAT
Lancer Engine Tech
Jan 23, 2013 05:55 AM
philamthebest
Jul 18, 2012 03:02 PM
jeffm1999
16
Sep 18, 2003 08:20 AM
