Headers with Emissions testings
Old Apr 6, 2004 | 11:22 AM
Drive02Lancer's Avatar
guess ill get that "auterra dyno-scan tool" for the palm, since i got a palm IIIc, ill use that and ill get eManage and have a labtop, im sure i could tune/adjust to get around the CEL lights mua ha ha ha after i get headers im getting full exhaust, than the 3g eclipse MAF like rhyzin and just tune my car to its potential woot!
Old Aug 8, 2019 | 11:16 AM
Csan4500's Avatar
Running headers 3 codes bypass or replace sensor?
Originally Posted by AdamJ39
near all CEL lights will fail you in emmisions testing through the ECU...so if u have any casued be the header your going to install you may fail i would test it with the Headers on first...then if you fail...take them off...no big deal really
-Adam
Installed a header on my 06 lancer es 2.0 was having the warm up efficiency below threshold code showing before replacing stock manifold/cat and now it is shooting p0133 circuit slow response p2195 sensor signal stuck lean bank 1 sensor 1 and p0134 circuit no activity detected bank 1 sensor 1 should I check the wiring or replace the sensor, oh and i installed one of those mini cats
MR.ev021
23
Dec 4, 2016 04:54 AM
spyderx
Southeast Region
Feb 25, 2011 12:01 AM
Blue Evo 8
Automotosports - Illinois
Jul 2, 2007 09:18 AM
DarrenJ
49
Oct 27, 2005 06:46 AM
