Map Sensor low Voltage
Old Apr 24, 2020 | 01:22 PM
Ragu's Avatar
I'm new to the forums but I have a question. My 03 Lancer es has a problem with the MAP sensor, the code is p0107 (correct me if I'm wrong) because it has low voltage. It idles rough n the rpms drop after driving a while to the point that the car turns off if I stop for too long (a red lightlight). I replaced the sensor n the problem continued so I used a multimeter to check the voltage n two of them are low while the other is at the proper level.
How can I fix this? I'm in the learning process for cars so anything n everything is really helpful
Old Apr 25, 2020 | 05:47 AM
Welcome @Ragu
Ive copied your post in the forum where you will get more views & hopefully some assistance
Joe
Old Apr 25, 2020 | 06:48 AM
Biggiesacks's Avatar
My advice for next steps would be to inspect the wiring harness, pay special attention to the terminals in the connectors for the sensor and the ecu. Use a multimeter to test continuity and resistance between the the two connectors. Also check all your chassis grounds, especially engine to chassis and ECU to chassis. Make sure they are tight and free of corrosion.
evoredy
Apr 17, 2025 09:23 PM
Keller
Apr 5, 2010 02:10 AM
SSKILLA
Mar 31, 2008 08:16 PM
vroomevo
Jan 12, 2007 09:07 AM
vroomevo
Jan 7, 2007 08:10 PM
