Camshft Position Sensor
Old Apr 15, 2004 | 01:26 PM
Gemini_Lancer's Avatar
Unhappy Camshft Position Sensor
I drive a 2002 Lancer OZ, bought it at 36,000 miles, it now has 40,665 or thereabouts.
I have encountered my first Service Engine Soon light so I took it back to the dealer, the day I took it in the light went off.
They said it was a glitch but they kept it for a whole afternoon.
Picked it up at 5:30 Yesterday and before I got home the light came on.
Took it back to the dealer today, waited an hour before they told me they needed to keep it all afternoon to run diagnostics.
I just got a call from the dealer saying that a Camshaft Position sensor is going out and that's why the Service Engine light is going on, off and back on.
$150 is what he quoted me, does that sound resonable?
Anyone else had this happen?
Thanks,
Old Apr 15, 2004 | 01:43 PM
psy-q's Avatar
Isn't that still under warranty? Free is a better price
Old Apr 15, 2004 | 01:44 PM
uranium9v's Avatar
If not under warranty, thats not bad...does that include install?
Old Apr 15, 2004 | 02:20 PM
Under warranty....No
I believe the $150 does include install, it had better since I'll be tossing all my living/fun money from this paycheck at it.
I was hoping it wouldn't be this soon that stuff would start going bad on my Lancer, 40,000 miles isn't that much is it?
Old Apr 15, 2004 | 05:27 PM
Dem_z's Avatar
Camshaft position sesonor?... Seems rediculously complicated, and quite unusual....
And its not covered by warrenty?... I thought powertrain included everything that makes the car move... Like the camshaft... I dunno anymore...
Old Apr 15, 2004 | 05:37 PM
petey pab's Avatar
he has 40000 miles on the car...........why would it be coverd under warranty???
Old Apr 15, 2004 | 05:43 PM
jaymz916's Avatar
because bumper to bumper goes to 36K, powertrain goes to 60K, which includes engine.
Old Apr 15, 2004 | 05:44 PM
Dem_z's Avatar
Off the site:
Every new 2004 Mitsubishi now comes with even more extensive coverage to ensure your satisfaction, including a 10-year/100,000-mile Powertrain Limited Warranty, a 7-year/100,000-mile Anti-Corrosion/Perforation Limited Warranty and a 3-year/36,0000-mile New Vehicle Limited Warranty. Please see your local participating Dealer for Limited Warranty terms and conditions.
Note: The 10-year/100,000-mile Powertrain Limited Warranty applies only to the original owner of new, retailed 2004 models.
///(Pay attention to this part)///
Subsequent owners receive the balance of the Powertrain Components coverage of 5-years/60,000-miles under the New Vehicle Limited Warranty.
liquidlancer's Avatar
hahah cps sensor is one little 10mm bolt it pops right out
if you want to buy oen ill sell you the acualy sensor and ill give you pictures about how to put it in
its easier then changing a sprak plug
did they tell oyu how much labor is on the part?
the part only cost 52 dollars :-)
Old Apr 16, 2004 | 05:57 AM
camshaft position sensor
The manager said he thought it might be covered, but then I guess he discovered either I wasn't the original owner or that the powertrain warranty doesn't cover the cps.
quote: "if you want to buy one ill sell you the acualy sensor and ill give you pictures about how to put it in its easier then changing a sprak plug" end quote:
The manager told me $150, however ((liquidlancer)) if it's as easy to install as you say, then they are making close to $100 of me on labor.
I'd be better off saving $$ by doing it myself, I'm generally ok when it comes to car mechanics however I've never had a newer car like my lancer. Gotta learn sometime though.
Hey liquid, could you go ahead and show me how replacing this part is done and I'll decide if I should try it, if you need my email just reply back. $52 doesn't sound that bad for the part anyhow.
Thanks,
Old May 6, 2004 | 05:15 AM
Unhappy Cps
Ok, it's been awhile and I really, really need to get this fixed. On good days it only takes 10 minutes for my car to actually start, on bad days I'm sittting there for half an hour consistantly turning the ignition over, then letting it sit, then turning it over and letting it sit.
Hey LiquidLancer! I really would like to get that part from you, and a detailed explanation on how to install the new cps.
Or does anyone know where I can order the part??
Thanks,
Old May 6, 2004 | 07:58 AM
KillahB's Avatar
You can get a new cam position sensor from the dealer, if push comes to shove. In my 4G93, I have changed it out twice (once when I did not know what I was doing and had a mechanic rape me, and the other time, was easy)... I got the part from the dealer and it cost me about 50 bucks and 10 minutes of my time.
Old May 6, 2004 | 08:39 AM
CPS from dealer
Thanks AirQuez....more ?'s though,
Do I just call up the dealer and order the part from the Service Dept? Will they even sell it to me?
Could you give me a detailed description of the process of taking out the old and putting in the new sensor?
Thanks, I appreciate it greatly
Old Jun 7, 2005 | 09:43 AM
JDog's Avatar
I've started having the same problem - sporadic check engine light, code reads as P0340, camshaft position sensor malfunction. Very similar mileage as Gemini Lancer - 43,000.
Two questions:
Is driving with this problem until I can get it fixed likely to cause any further damage?
What exactly is involved in replacing the part?
Any advice would be greatly appreciated. Thanks!
Old Jun 7, 2005 | 10:07 AM
HobieKopek's Avatar
The sensor is just a little piece of plastic with a magnet in it. It's about the size of a thumb, black, and sits by the driver's side end of the cam shaft. Unless the other part (which isn't actually the sensor and I can't remember the name of) is broken, in which case it'd be a 20 minute fix instead of a 5 minute fix.
