ECU rom issue
Old Jun 16, 2021 | 03:48 PM
Sogek's Avatar
ECU rom issue
Hello everyone
I got tactrix from china "fack one" i try put it in my car, trying to read from ecu, start ecuflash, select vehicul type "CAN vehicules HM8106F / 2006+ / memory model : M32186F8"
click at read from ECU's flash memory. turn ignition on the "ON" position. and press OK button to continue.
i think the first time the VIN car is read by the tools. after few seconds the connexion is lost.
i try to do the same think second time. but the fan / and lot of errors message is shown in the board (service required steerin wheel /check temperature/ check motor oil / service required battery...) the car didn't start up, only crank.
some people told me to exit programming stat. but without a result.
[20:10:38.533] EcuFlash Version 1.44.4347
[20:10:38.533] OS Version Windows 8
[20:10:38.533] Qt Version 5.2.0
[20:10:38.549] 67 memory models read.
[20:10:38.549] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[20:10:38.642] 745 ROM metadata models scanned.
[20:10:38.642] checksum module "subarudbw" loaded.
[20:10:38.642] checksum module "subarudiesel" loaded.
[20:10:38.642] checksum module "mitsucan" loaded.
[20:10:38.642] checksum module "mitsuh8" loaded.
[20:10:38.642] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[20:10:38.642] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[20:10:38.642] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[20:10:38.658] flashing tool "wrx02" loaded.
[20:10:38.658] flashing tool "wrx04" loaded.
[20:10:38.658] flashing tool "sti04" loaded.
[20:10:38.658] flashing tool "sti05" loaded.
[20:10:38.658] flashing tool "mitsukernel" loaded.
[20:10:38.658] flashing tool "mitsukernelocp" loaded.
[20:10:38.658] flashing tool "mitsubootloader" loaded.
[20:10:38.658] flashing tool "shbootmode" loaded.
[20:10:38.658] flashing tool "shaudmode" loaded.
[20:10:38.658] flashing tool "subarucan" loaded.
[20:10:38.658] flashing tool "subarucand" loaded.
[20:10:38.658] flashing tool "subarubrz" loaded.
[20:10:38.674] flashing tool "subaruhitachi" loaded.
[20:10:38.674] flashing tool "mitsucan" loaded.
[20:10:38.705] J2534 API Version: 04.04
[20:10:38.705] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.705] Device Firmware Version: 1.17.4877
[20:10:38.705] Device Serial Number: TAhJALxt
[20:10:38.705] interface close
[20:10:38.736] J2534 API Version: 04.04
[20:10:38.736] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.736] Device Firmware Version: 1.17.4877
[20:10:38.736] Device Serial Number: TAhJALxt
[20:10:38.736] interface close
[20:10:38.768] J2534 API Version: 04.04
[20:10:38.768] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.768] Device Firmware Version: 1.17.4877
[20:10:38.768] Device Serial Number: TAhJALxt
[20:10:38.768] interface close
[20:10:38.799] J2534 API Version: 04.04
[20:10:38.799] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.799] Device Firmware Version: 1.17.4877
[20:10:38.799] Device Serial Number: TAhJALxt
[20:10:38.799] interface close
[20:10:38.830] J2534 API Version: 04.04
[20:10:38.830] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.830] Device Firmware Version: 1.17.4877
[20:10:38.830] Device Serial Number: TAhJALxt
[20:10:38.830] interface close
[20:10:38.861] J2534 API Version: 04.04
[20:10:38.861] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:38.861] Device Firmware Version: 1.17.4877
[20:10:38.861] Device Serial Number: TAhJALxt
[20:10:38.861] interface close
[20:10:44.442] J2534 API Version: 04.04
[20:10:44.442] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:44.442] Device Firmware Version: 1.17.4877
[20:10:44.442] Device Serial Number: TAhJALxt
[20:10:48.905] -- connecting to kernel --
[20:10:48.905] kernel get version
[20:10:49.062] ECU HW part number : 1860A800
[20:10:49.109] ECU SW part number : 1860A80001
[20:10:49.874] -- unlocking ECU --
[20:10:49.874] starting session...
[20:10:49.874] requesting seed...
[20:10:49.874] sending key...
[20:10:50.171] interface close
[20:10:50.202] interface close
[20:10:54.857] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[20:10:54.889] J2534 API Version: 04.04
[20:10:54.889] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:10:54.889] Device Firmware Version: 1.17.4877
[20:10:54.889] Device Serial Number: TAhJALxt
[20:10:56.796] -- loading kernel --
[20:10:56.796] -- connecting to kernel --
[20:10:56.796] kernel get version
[20:10:56.932] ECU HW part number : 1860A800
[20:10:56.952] ECU SW part number : 1860A80001
[20:10:56.952] -- unlocking ECU --
[20:10:56.952] starting session...
[20:10:56.962] requesting seed...
[20:10:56.972] sending key...
[20:10:57.262] interface close
[20:10:57.293] interface close
[20:11:08.132] J2534 API Version: 04.04
[20:11:08.132] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:11:08.132] Device Firmware Version: 1.17.4877
[20:11:08.132] Device Serial Number: TAhJALxt
[20:11:10.444] -- connecting to kernel --
[20:11:10.444] kernel get version
[20:11:10.604] ECU HW part number : 1860A800
[20:11:10.654] ECU SW part number : 1860A80001
[20:11:11.427] -- unlocking ECU --
[20:11:11.427] starting session...
[20:11:11.427] requesting seed...
[20:11:11.427] sending key...
[20:11:11.724] interface close
[20:11:11.739] interface close
[20:11:19.165] J2534 API Version: 04.04
[20:11:19.165] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[20:11:19.165] Device Firmware Version: 1.17.4877
[20:11:19.165] Device Serial Number: TAhJALxt
[20:11:21.168] -- reading ECU ID --
[20:11:21.296] ECU HW part number : 1860A800
[20:11:21.316] ECU SW part number : 1860A80001
[20:11:21.316] interface close
[20:11:21.337] interface close
please if some one have the same issu, and can help. I'll be grateful
Old Jun 17, 2021 | 10:31 AM
stroopwafel's Avatar
What year is your Lancer? Did you connect your OP2.0 to a laptop with internet access? Cause that might cause it to lock up. Are the drivers installed correctly?
See attachment for recovery flash instructions
File Type: pdf
Bad_Lad
Apr 19, 2020 05:09 PM
nvr2fst
Jul 28, 2011 01:41 PM
lonestarevo83
Jul 15, 2011 07:20 PM
waskarn
Mar 26, 2011 07:04 AM
rolly1818
Nov 25, 2008 05:09 AM
