Plugs
Old May 22, 2004 | 09:00 PM
Inspectah07's Avatar
Plugs
Hey guy i know this has been covered alot. But i wanted to know how many spark plugs our engine has. We have 4 correct. Also can any body show me a how to install spark plugs. And one last thing what plugs are the best i was going to go with NGK Plugs. Let me know please
Old May 22, 2004 | 09:07 PM
differentstroke's Avatar
Yes you have 4 plugs NGK is a good brand take off cover, pull off wire (remember what wire goes where) unscrew plug, gap new plug,screw in new plug put wire back on and cover done (should take 10 min.)
Old May 22, 2004 | 09:12 PM
what kind of tool do you use to take off the plugs. And have you heard of NGK V-POWER is that good. I went to my local checkers and they were 1.99 each that is cheap should i get a better type.
Old May 23, 2004 | 12:29 AM
KillahB's Avatar
Because it is cheap does not mean it does not work well.
Old May 23, 2004 | 01:33 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
You'll want a spark plug socket, it's like a regular socket but it has rubber inside to hold onto the spark plug and pull it out. Run a search for spark plug and you will find a lot of controversy as to which plugs to get. Very easy to do. Disconnect your battery, gently pull off the rubber boots, unscrew and remove the old spark plugs, screw the new plugs in (snug), replace the boots, connect your battery, done!
guapoholic
24
Feb 24, 2017 07:47 PM
deadbeatrec
Feb 16, 2008 05:48 AM
TMRVA
23
Aug 31, 2007 11:32 AM
ModifiedOZ
Lancer Troubleshooting
Nov 21, 2005 10:32 AM
donduck
Lancer Engine Tech
11
May 23, 2005 06:48 AM
