RRM Turbo and exhaust leak
Old Jun 22, 2004 | 07:31 AM
Boeturbolancer's Avatar
I've never seen this problem with an RRM header... in fact i've taken mine on/off several times repairing leaks and doing bolt checks. I had my gasket go out from my header to my uppipe a couple times... due to my bolts coming loose and it burned it out. Was my fault as i heard it and took my sweet time to check it.
I usually just take the assembly out for bolt and gasket checks when i think there is an issue. I've never gotten a new exhaust manifold gasket... NEVER!! I'm still using the original one from when i baught the car. Never have had an issue.
I know the new headers from RRM are CNC'd and checked. But i've never had an issue with mine and it's a second gen one.
Old Jun 22, 2004 | 07:39 AM
Guru_Del's Avatar
i second that. taken it off 3 or 4 times, not leaks, i did have a leak where the header met the up pipe but that was my own damn fault for not tightening it down cause i have girly hands.
I have the newest rrm header generation which ever that is.
Old Jun 22, 2004 | 09:31 AM
josh930's Avatar
Get some soap and water, put it in a spray bottle and spray where you think its comming from.
Old Jun 22, 2004 | 09:33 AM
pgmike's Avatar
why would i do that?
Old Jun 22, 2004 | 09:37 AM
pumpdog720's Avatar
I believe the tourqe specs for the bolts on the header are 12ft lbs on the bolts and 14ft on the 2 outside bolts.
I tourqed mine down to that with a tourqe wrench. And some of you may have known that I have a sputtering problem. I looked and there is like a black buildup up around the corner of the header. Could it be leaking? And could and exhaust leak make your car sputter and like hesitation?
Sorry for jacking the thread.
Old Jun 22, 2004 | 09:44 AM
HobieKopek's Avatar
This is on a car that's running. I don't think that would be a very good idea.
Old Jun 22, 2004 | 11:48 AM
jeezer's Avatar
12ft lbs for the 12mm and 22ft lbs for the 14mm
ROAD/RACE
http://www.roadracemotorsports.com/
Old Jun 22, 2004 | 02:29 PM
4g94T's Avatar
no its 12mm nuts are 12ftlbs... the two outside 14mm outside bolts are 14ftlbs.
Old Jun 22, 2004 | 07:10 PM
DEVOTED's Avatar
Where did you get your numbers from?
Old Jun 22, 2004 | 07:11 PM
pumpdog720's Avatar
Hmmm.. I think I will go with jeezer's specs. Haha!
(I don't know why, but I just have a feeling he might know )
Old Jun 22, 2004 | 10:08 PM
4g94T's Avatar
well i emailed boe last night about it because im thinking about getting the headers this week, thats what he told me
Old Jun 22, 2004 | 10:25 PM
HobieKopek's Avatar
ROAD/RACE
Correct. Verified by service manual for the non-believers.
Old Jun 22, 2004 | 10:32 PM
pumpdog720's Avatar
Well jeezer does happen to work for RRM if I'm not mistaking.. heh.
Old Jun 22, 2004 | 11:12 PM
Yeah... jeezer is right i accidentally said 14 for 14 instead of 22 for 14. was a typo. Sorry about that.
Old Jun 23, 2004 | 09:29 AM
pgmike's Avatar
ok thanks a lot for the info nicktutt
Chokkan
23
Mar 9, 2017 11:38 PM
RelentlessEVO
Feb 27, 2017 10:02 AM
simons3z
13
Feb 3, 2017 03:52 PM
Gh3ttoRoM3o
Oct 5, 2015 09:52 AM
sykou
Lancer Troubleshooting
32
Jan 5, 2006 05:01 PM
