moroso pulley
moroso pulley
i was at www.autopartsperformance.com and they have things for the lancer, i am curious aout the pulleys they have. what will a pulley do for my car? also what will a V-force power control module do?
the pulley goes on the front side of the engine on the outside and it is linked to the timing gear i do believe...if you remove that black plastic thingon youre mototr that is int the middle of all that fan belt mess...you will find the crankshaft pulley wheel...tada
since dohc have 2 of them our sohc will only have one...and companies claim a 12 to 14 hp increase with these new lightweight pulleys...
Pulley kits are one of those 'must' mods for our under powered engines. I have AEM pullies on my Eclipse and plan on pullies for the Lancer, since that Moroso alt. pulley is only 50 bucks I'mm probably go ahead and pick it up.
For fitment issues, I have a dremel.
No, if it doesn't fit right, I'll just return it. But it did say all Mitsu models. And all the other models have the same part and part # listed. But I will let you all know how it goes, if it goes on good, I'll post pics.
DaddyLongStroke
Jan 5, 2017 06:22 AM
detnow2009
Aug 15, 2015 02:45 PM
bnr34rb26dett
Nov 11, 2011 07:18 PM
tx evo
34
Nov 26, 2003 12:58 PM
