Coolant Temp
Old Jul 27, 2004 | 03:10 PM
eLiTe eVo's Avatar
Coolant Temp
my sister has a OZ lancer, doesn't take care of it properly, therefore problems arise... anyway, when she sits in traffic without keeping a speed up, her coolant temperature shoots up, almost all the way as high as it can go. but once she starts driving, say on the highway or something, it goes back to just below halfway like normal. what can i get done to not have this problem happen anymore? i have a lancer evolution myself, and ive never had the problem.. but then again she and i view cars completely different, hence them being in very different condition, heh.
--KiD
Old Jul 27, 2004 | 03:48 PM
EdT's Avatar
EdT
First of all check if the coolant is properly mixed 50/50 water by using an anti-freeze hygrometer, next check if the water pump is not seized or if the thermostat is functioning.
Old Jul 27, 2004 | 04:23 PM
Automatic 51's Avatar
try and check the thermostat and the fan relay switch. my old car had problems like that and those combined were the culprit. i could be wrong though. i'm no mechanic.
Old Jul 27, 2004 | 04:48 PM
Myszkewicz's Avatar
My '91 Eclipse did that. Turned out to be the fuse for the radiator fan.
Old Jul 28, 2004 | 12:50 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Fan, thermostat, or not enough coolant/water. If she's had to refill an empty coolant reservoir, make sure she also filled the radiator or it might not syphon from the reservoir anyway. My friend has the same problem with his Civic, so I'm finding new things to check on his from this thread now. Thanks!
Old Jul 28, 2004 | 10:00 AM
HobieKopek's Avatar
There's also a large flat spot on moster themostats/gauges, so if she notices it going much higher than normal that could be a big increase in temp. Definitely check fans and coolant. A lot of coolant comes premixed nowadays, so you don't have to worry about a proper 50/50.
Old Jul 28, 2004 | 09:17 PM
EdT's Avatar
EdT
Thats when you precisely have to worry, theres so many brands and types of coolant on the shelves today that someone with no mechanical background would make a mistake, even mechanics make mistakes with coolants today. I was at the local auto store when someone asked me which type off coolant he should use on his Toyota Tercel, it turns out he added Dexcool based coolant straight without adding any water after I told him to buy a hygrometer to check if it was straight, dang it was straight and his engine was almost overheating and his coolant was a thick and gooey with metal particles floating around.
Old Jul 28, 2004 | 09:20 PM
pgmike's Avatar
also check the radiator hose, mine got pinched real bad once and my engine temp went way up.
Old Jul 29, 2004 | 11:28 AM
HobieKopek's Avatar
I have never had a problem in 7 years. Something tells me bad mixes like that are flukes. I'm not saying they don't happen, just that they don't happen often to a degree that will have any effect on your car.
Yeah, sounds like your friend should just read the labels on products.
Toaster Label:
Do not operate in shower or bath.
StaticOasis
Lancer Troubleshooting
Aug 29, 2016 08:57 AM
ittick
Jul 16, 2013 08:58 PM
TeachersEvo
Jul 31, 2012 06:54 AM
evo_soul
Toronto Lancer Club
24
Dec 13, 2010 04:28 AM
EVO_GUY
12
Feb 19, 2005 12:44 AM
