Loss of Power
Old Aug 9, 2004 | 03:46 PM
petey pab's Avatar
Loss of Power
ok, i have a problem. my car has just over 40000 miles on it and im experiencing a loss in top end power. my trap times have gone from 84 mph down to 79 mph. im not sure if its just the hot weather or what. i think it has something to do with my fuel system and i thought it was the fuel filter, but i found out that our filters are in-tank and a part of the fuel pump. i dont know if i should try and replace the fuel pump or what. but its really kinda bummin me out so any help is appreciated.
Old Aug 9, 2004 | 03:54 PM
JDM_FeTiSh's Avatar
From: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
is ur service up to date. lke changin ur air filter, cleanin ur fuel system etc???if ur over 40,000. im sure u did ur 30k. thats one of ur major service. gota put new fluids in etc. check everythn in n out of ur car.
hpe this helps.
one
Old Aug 9, 2004 | 03:58 PM
petey pab's Avatar
i keep up on all my own maintenance, so i doubt thats it. i go to the track almost weekly and my car has always been VERY consistent. its just in the recent weeks that its been performing poorly. im hoping its just the heat, but i dont know.
Old Aug 9, 2004 | 03:59 PM
JDM_FeTiSh's Avatar
not sure.. probably..
Old Aug 9, 2004 | 04:11 PM
Archangelite's Avatar
it probably is the heat. the days have been hotter these two last weeks.
Old Aug 10, 2004 | 12:17 AM
petey pab's Avatar
i thought it was the heat too. but the thing is, i went from hittin 16.2-3's with 25 lb. rims to hittin no better than 16.5 with 11 lb rims! youd figure if it was the heat, id at least be able to run what i was when it was cooler. but as it is, i should have knocked off close to 4 tenths with the rims i have now, but ive only been running slower.
Old Aug 10, 2004 | 06:54 AM
WADADLIG_OZ's Avatar
It's probably the heat.
Here in Florida my times have suffered a bit also since the heat and humidity have picked up.
Be patient. I think with the colder air on the horizon things will speed up again.
Oh I should add that I noticed that my 60' times are alot worse than before I don't know if tires have to do with it too but definitely my trap speeds are down.
WADAD
Old Aug 10, 2004 | 07:07 AM
HobieKopek's Avatar
Heat = ECU retards timing = slow.
It will go back to normal I'm sure, but it may take some time. If you want to test it you could always just reset the ECU.
Are you sure it's not just inconsistent driving? It's not hard to lose time with even just a slight change in shifting or accelerating.
Old Aug 10, 2004 | 05:42 PM
petey pab's Avatar
im pretty sure its not incosistent driving. i track my car weekly since last year and its always been very consistent. i do remember my times got worse around this time last year as well, but i just thought it was cause i didnt know what i was doing. but resetting the ecu would work? i still havent hooked up my piggyback, so do you think i should wait until the weather cools down to really test it?
Old Aug 20, 2004 | 10:24 PM
petey pab's Avatar
any other ideas?
Moronicicon
Lancer Engine Management / Tuning Forums
Jun 29, 2017 10:15 PM
evoviiihan
10
Oct 22, 2016 10:00 PM
AutoEuphoria
Apr 23, 2016 08:11 PM
Mikami
Aug 28, 2015 03:11 PM
David Buschur
74
Jan 17, 2007 07:09 AM
