what happens to Mass Air Flow Sensor(i think?) after a cold air intake installation?
Old Sep 6, 2004 | 02:29 AM
dangerous-desi's Avatar
(i am not even sure if that is what its called)
I've bought an AEM Cold Air Intake, i am just wondering how would i plug it in when there is a sensor plugged in right on top of the stock Air Filter, I am not sure whether the American Lancers have the same setup, but that is how the Canadian Lancers are setup.
Anyhow, what to do with that sensor? would the ECU of the car be affected by removing it? i am sure if it's plugged into the ECU, then it must serve some purpose and removing it must cause some sort of a disturbance in the ECU?
thanks in advance.
Old Sep 6, 2004 | 05:35 AM
petey pab's Avatar
the only plug on the intake is the MAS. the AEM intake has two pipes so you can put the MAS between them.
Old Sep 6, 2004 | 11:35 AM
pgmike's Avatar
do NOT remove it. its necessary for your car to run properly.
Old Sep 6, 2004 | 12:11 PM
thanks bro(s).
Old Sep 6, 2004 | 11:57 PM
LancerOZ's Avatar
Yes. You place the MAS (Mass airflow sensor) between the two pipes. Once the MAS is installed between the two AEM pipes, you connect the wire-harness back up to the MAS. Your AEM installation instructions should show this with pictures, mine did.
If you have problems, let me know, and I'll go take detailed pictures for you.
- Jason
Larry3
Lancer Engine Management / Tuning Forums
Nov 3, 2021 01:54 PM
elpoole
Lancer Engine Tech
20
May 8, 2008 11:45 AM
herdfan2005
Jan 18, 2005 04:00 PM
illuminati
May 1, 2004 11:05 AM
digdat
Lancer Engine Tech
Apr 1, 2004 12:43 PM
