Drive Belt Removal
Old Nov 5, 2004 | 07:27 AM
Danno's Avatar
Drive Belt Removal
I know htat this has been discussed many of times but I couldnt find a How To on it. I need to know where the tensionar is. I couldnt seem to find it (but Iam a little a Sleepy) If anyone knows where there is a how too or has done it and feels like providing me with some insite tht would be great.
BTW
Iam Talking about the Belt that goes from the Crank Shaft Pully to the Power steering pump pully and the AC Pully.
Cheers
Danno
Old Nov 5, 2004 | 07:46 AM
HobieKopek's Avatar
The tensioner is right above the AC compressor and below the power steering pump (if I remember correctly). It's a 14mm bolt if I remember correctly, and it's very easy to remove. I believe it's called the accessory belt though just FYI.
Old Nov 5, 2004 | 07:48 AM
Danno's Avatar
I was hoping you would answer me, lol. Thanks man.
Old Nov 5, 2004 | 07:58 AM
Danno's Avatar
Its the bolt that is towards the frong of the car not the one on the pully correct?\
Is it reverse thread or anything like that?
Old Nov 5, 2004 | 08:01 AM
HobieKopek's Avatar
Correct. I don't remember which way it's threaded, but if you just give it a few turns you can see the tensioner that the bolt is attached to. You should be able to determine whether it's getting tighter or looser just by taking a peek at it.
Old Nov 5, 2004 | 08:09 AM
Danno's Avatar
Awsome, Thanks
Old Jan 31, 2005 | 06:13 AM
Kurt's Avatar
I'm bringing this thread back. Over the weekend I went to change my belts. I found the tensioner and the bolt that goes to it. I have one big problem, no matter which way I turned it, I could not get the tensioner to loosen. Any help would be great. I really don't want to take my car to the stealership.
Old Jan 31, 2005 | 12:51 PM
airlinevomitbag's Avatar
Look on the side for a cross bolt that locks the tensioner in place. Crack that first then the tensioner will move freely. I just did all the belts on a Galant and thats how both accessory belts are and I highly doubt it is different on our cars. FYI reverse threads are extremely uncommon especially on areas where routine maintenance is performed.
Old Jan 31, 2005 | 12:52 PM
Kurt's Avatar
Thanks, I will give that a try when I get home.
Old Feb 7, 2005 | 05:21 AM
Kurt's Avatar
Airlinevomitbag, thanks for your suggestion. I got some free time over the weekend and got the belts change. Your little hint helped.
Old Feb 7, 2005 | 06:44 AM
No problem
Old Mar 26, 2006 | 09:03 AM
blaze_125's Avatar
Let me bump this 1 year old thread for some info What length/width is our belt... would any car parts store have it, or am I stuck with stealership pricing? Anyone's got a part# for me?
Old Mar 26, 2006 | 10:58 AM
HobieKopek's Avatar
http://www.mitsubishiparts.com should have a part number. I don't know offhand.
Old Mar 26, 2006 | 11:08 AM
blaze_125's Avatar
Thanks Hobie
Old Mar 26, 2006 | 01:06 PM
iyi0521's Avatar
Holy Crap. $34 for a belt. thats nuts.
