Drive Belt Removal
Old Mar 30, 2006 | 05:29 AM
jeemybo's Avatar
Autozone sells generic (goodyear) belts for $20-25. You don't need a part number, they can look it up for you. As far as I can tell these belts are fine, they pull my supercharger as good as anything, so I imagime they should work fine with the accessories.
Old Apr 3, 2006 | 08:02 PM
9g's Avatar
9g
i need to do mine soon. great info here.
Old Jun 6, 2006 | 05:33 AM
Kurt's Avatar
I hate the tensioner pulley. I had to replace the Goodyear belts that I bought because the drive belt was start to get cracks in it. For some reason when I go to tighten the tensior bolt it goes off to the side. What do I need to do to tighten the that bolt straight? As of now I need to most likely replace my tensioner pulley because of this.
I am refering to the bolt circled in red
Old Jun 6, 2006 | 05:56 AM
airlinevomitbag's Avatar
Snug up the other bolt that "locks in" the tension bolt and then back it off a 1/4 turn and then re-tension. That bolt on the side lets the tension one slide off if its too loose.
Old Jun 6, 2006 | 06:25 AM
Kurt's Avatar
I will try that at lunch.
Old Jun 6, 2006 | 08:07 AM
comatose721's Avatar
post #214 on page 15 of the following thread:
https://www.evolutionm.net/forums/sh...&page=15&pp=15
those pictures and diagrams are everything you will need.
mark
Old Jun 6, 2006 | 08:40 AM
Kurt's Avatar
Very informative. Thanks for sharing.
Old Jun 6, 2006 | 09:43 AM
Kurt's Avatar
After lunch update. I got the bolt a little bit straighter. That thing is a b!tch to tighten straight. After busting a knuckle, I called it quits until later tonight.
Old Jun 6, 2006 | 10:02 AM
Kurt; do what he had mentioned. if that isn't helping at all it is possible you may need a new tensioner pulley.
Old Jun 6, 2006 | 10:16 AM
Kurt's Avatar
I will. It's just a pain to work in that spot without removing the cooling fans. That creates so much more work space.
Old Jun 6, 2006 | 10:22 AM
it's much easier to reach fom underneath the vehicle if you are using a socket wrench OR a wratcheting wrench is ideal. mine fits in there with plenty of clearence and your knuckles don't get torn apart by the fan shroud.
Rasperin
May 1, 2017 12:25 PM
mattsrbu
Evo X How Tos / Installations
Nov 2, 2016 10:04 PM
KenyonKanye
For Sale - Part Outs
Feb 14, 2016 10:38 AM
saxon
Northeast Region
Oct 29, 2015 04:20 PM
