How can I know my brake is finished?
Old Dec 23, 2004 | 03:42 PM
initialD's Avatar
I mean can I check the break myself? I need know its situation before they are total finish!! my car is 25k km!!!!
some way to check this out/?
Old Dec 23, 2004 | 03:46 PM
twardnw's Avatar
you mean, how can I check to see if my brake pads are worn out? Take off your wheel, look at them, I would replace them when the pad surface gets to be about 1/4" thick
Old Dec 24, 2004 | 02:09 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Also, brake pads usually have a squealer plate that will make a harsh metal sound when the pads are close to worn. The only downside to that is if you drive it too long with that sound, you'll be tearing your rotors up as well.
Now as for the suggestion above, when you're looking at them, just keep in mind that brand new pads on the Lancer usually have about 1/3" of meat on them. If you're down to 1/8" you probably need to replace them, and 25-30k seems to be the common mileage for Lancers to need new pads. Checking your rear drum brakes is a tad more involved, but come back in another 25k miles and ask us about that.
GrandmasterCow
Apr 1, 2013 05:33 AM
Dragking2189
Jan 16, 2011 01:26 AM
golgo13
May 31, 2010 11:10 AM
08MitsubishiGTS
May 21, 2008 09:55 PM
evoviiiyou
130
Apr 26, 2005 09:28 AM
