Which Header
Old Feb 18, 2005 | 05:14 AM
  #31
sthiewes's Avatar
Originally Posted by lookslikeanevo
now the only way you will pass emission is if your car has been running and has been warmed up...but in most states you will not pass the visual part if you have one...since they will see you have a header
I could just put the heat shield back on that way it covers the header right?
Old Feb 18, 2005 | 07:36 AM
  #32
Al Banks Holla's Avatar
Doubt it. The sotck heat shield probably won't fit over the new header as the flanges come out a little further.
Old Feb 18, 2005 | 07:52 AM
  #33
sthiewes's Avatar
Oh..I thought I read in another thread that they put the heat shield over the new header.
Old Feb 27, 2005 | 11:22 AM
  #34
DjDoubt's Avatar
Could some one please give me a step by step on how to install the MIL? I've had it and my headers for almost a year but never put the MIL on.
Thanks
Old Mar 13, 2005 | 10:54 PM
  #35
joshthegreat's Avatar
we have 2 cats and 2 o2 sensors
1 o2 sensor is before the first cat in stock header, and the second o2 is right before the 2nd cat.
when stock: the 1st o2 will read diry air and the 2nd will read clean air...
after a header install, 1st cat is eliminated and now both o2's are reading dirty air.
if you turn your 2nt cat around(the only one you can turn around) so that the 2nd o2 is after the 2nd cat instead of the 1st, then your 1st o2 will again be reading dirty, and since your 2nd o2 is not after the cat which cleans the air, it will now read clean air therefor getting rid of CEL
1st o2 sensor is for air fuel 2nd o2 sensor make sure ur 1st cat is still there
Old Apr 19, 2005 | 03:00 PM
  #36
sadude's Avatar
hold up...if u flip your 2nd cat around...can't u just leave it that way all the time???
from the way its sounding you have to keep on switching it around???
thanks
Old Apr 19, 2005 | 03:56 PM
  #37
wiretap's Avatar
My stock heat shield fit over my RRM header, but it scraped it a tiny bit. The header really doesn't get extremely hot anyways. The ceramic coating keeps the heat in. Maybe this summer I might put it back on since it gets to be like 95 degrees here. Don't wanna choke out my SRI. That also might help on the visual inspection for other states.. When I put on the heat shield on the RRM header, it covered up everything so you could barely see the pipes coming out. If you glanced at it, the engine would almost look stock.
Old Apr 19, 2005 | 06:17 PM
  #38
K.I's Avatar
K.I
so when you install a new header you have to get it inspected? i dont get whats up with the inspections and tests n all
Old Apr 19, 2005 | 06:20 PM
  #39
wiretap's Avatar
MI doesn't have inspections or testing.. it varies state to state.
Old Apr 20, 2005 | 04:53 AM
  #40
sthiewes's Avatar
Depends on where you live. Here in Jersey it's like every 2 years our cars get inspected. 4 years for a new car.
Old Apr 20, 2005 | 10:28 AM
  #41
K.I's Avatar
K.I
ah ok thnx
Blacksheepdj
Dec 2, 2016 08:31 AM
06RAJK
Oct 29, 2016 09:58 AM
redozrally
Jul 23, 2006 03:02 PM
Walkingchaos
Lancer Engine Tech
Nov 26, 2005 06:17 PM
yaheardbish
Lancer Engine Tech
May 31, 2002 05:29 AM
