Blew Rod @ 42458M
no, I don't know exactly where it is, but if the ECU isn't monitoring oil level, then how does the oil light come on? Or I could be wrong and there's just no way for any of us to know that our engines are going to grenade on us at any minute because there's not a system monitoring any of it.
Could be---If I understand the system correct, the red oil pressure light on the dashboard has absolutely nothing to do with the Service Engine Soon light. I guess an example I can think of off the top of my head is when you change your oil and start the car the first time after changing it. The light comes on or flickers for a few seconds until the oil pressure stabilizes because the oil filter was replaced. (No oil in the filter at first.) This doesnt cause a Service Engine Soon light. I looked in the manual and there are no OBD II codes for "low oil level".
Originally Posted by erockOZ
^^ agree, there is a company on there that normaly has our engine used for around 200-250. if you pick up at there fright station, it saves some cash. good luck.
Originally Posted by ot gengineerboy
Kudos to him though for just owning up to it and asking for assistance in finding a new block/engine.
Sounds like both an oil issue and a possible hurting when you were doing turbo applications. More than likely you detonated enough and it hurt a rod bearing... over time the bearing wore in more and finally froze up. Once that happened the rod locked and got chucked do to the other cylinders still working.
Good luck with your repairs.
To back up dookie... there is no oil level indication for the lancer. Only thing it has is the oil pressure sensor. That is indicated via the oil can light in the dash. It a dummy ground style sensor... one wire... works on continuity principles.
Originally Posted by Biggwill91183
Yeah when things go so wroung you gotta ask for help, lol i thought i was doing a great job though. This is my 1st car that i have actually messed around with. My car befor that was a 1987 Dodge Dakota and dident do anything to that. So insted of me maybe buying an newer older car and trying to learn how things work i just bought a brand new one, and started on that, and i can see i f'ed that up. O well live and learn for our mistakes, or should i say mine.
FS[Northeast]: built 2.0L short block, pistons, buschur intake,
O0oDC
26
Sep 3, 2015 05:46 PM
FS[Northeast]: Freshly Built 2.3 Stroker Shortblock
O0oDC
13
Aug 14, 2015 11:51 AM
brian94ht
Nov 18, 2009 06:35 AM
