Blown Engine 4G69 swap
Old Jul 1, 2005 | 02:10 PM
  #31
livelyjay's Avatar
No big deal. Paul, run some searches on B15sentra.net. The Spec-V sentra has a returnless system, and they guys that install turbo kits on those cars convert their systems to a return system. They drill and tap into the fuel rail and run a return line, and probably add a fuel pressure regulator or upgrade the stock one.
Old Jul 1, 2005 | 02:20 PM
  #32
N1te's Avatar
doesn't sound like too big of an issue but glad to make it noticed
Old Jul 1, 2005 | 02:26 PM
  #33
senate6268's Avatar
Nah. Easy stuff. The Civic and Integra guys have to do the same stuff when a K-series engine is swapped in. The only difference is that they have the luxury of just getting an AEM fuel rail that's tapped on either end. Makes it a whole lot easier for the regulator and return line set up. The only concern in my mind is the drive by wire throttle system with the 4G69. Not sure what angle to take on that one.
Old Jul 1, 2005 | 07:56 PM
  #34
Jotun's Avatar
remove it.? Just go with a manual style throttle instead?
Old Jul 1, 2005 | 08:04 PM
  #35
rhyzin's Avatar
mmm, well traction control is programmed to the throttle by wire, where normal lancers don't come with abs. what an odd problem. would you require abs since the traction control is part of throttle by wire? could just end up being an annoying CEL.
Old Jul 1, 2005 | 08:08 PM
  #36
senate6268's Avatar
To go to a manual style throttle setup you would have to change the throttle body. I'm not sure what throttle bodies would mate up to the 4G69 that are not drive by wire.
Old Jul 1, 2005 | 08:22 PM
  #37
rhyzin's Avatar
also, there might not be anywhere on the intake manifold to bolt the throttle cable to. the holes would have to be tapped and threaded as well as find an acceptable donor throttle cable from a different car. not hard, just extra stuff.
Old Jul 1, 2005 | 08:36 PM
  #38
Jotun's Avatar
hell you can fab a plate to bolt just about anywhere and from the looks of the ralliart forums there are alot of 63 parts that fit it maybe the tb does. But hell thats half the fun of a swap trying to redneck your way through stupid problems.
Old Jul 2, 2005 | 03:27 AM
  #39
livelyjay's Avatar
If you need ABS, you could grab the items needed off of an 02-03 LS Lancer, just need to know what to look for.
Old Jul 2, 2005 | 11:07 AM
  #40
Jotun's Avatar
Putting ABS on a car is going to be harder than doin an entire swap. I will avoid this if at all possible I think the biggest issue that mayu arise is my brake light comeing on....
Old Jul 18, 2005 | 08:11 PM
  #41
N1te's Avatar
now I'm considering this swap. Jotun got his engine fixed and my engine just happened to blow. Any chance of the clutch and flywheels being the same?
Old Jul 19, 2005 | 06:57 PM
  #42
N1te's Avatar
What items would I need in getting ready for this swap? This needs to be done soon... I need a car and my car is sitting with a blown engine. Engine I'd need with intake manifold and all that obviously Altinator, etc.... What else?
Old Jul 19, 2005 | 07:35 PM
  #43
Jotun's Avatar
I really think this is going to happen we are putting the shopping list together as I type
look for this within a month or even sooner
Old Jul 19, 2005 | 11:51 PM
  #44
N1te's Avatar
RRM Said They are quite different plus bellhousing on the Lancer tranny is
different. Prolly going to be best to stick to the same motor. We have
a used motor in stock. Just letting you
know. RRM
what do yall say?
Old Jul 20, 2005 | 04:56 AM
  #45
livelyjay's Avatar
Get a used 4G94 block from a local salvage yard. www.car-part.com is your friend. If you need this NOW, stick with the stock engine and grab some forged internals while you're at it. Whatever you do, don't let the dealership do it for you and take away all your money. You're looking at about $2000 in parts, and do the swap yourself.
customtoyz
Jul 22, 2017 08:33 AM
Diavlo
Jun 19, 2017 03:24 PM
Ibrahim Nabil
Aug 6, 2015 05:22 PM
moamen nosseir
13
Apr 1, 2011 11:21 AM
OZER
Lancer Engine Tech
May 11, 2008 02:02 PM
