IM and cel
Old Nov 7, 2005 | 07:36 PM
rhyzin's Avatar
when you turn the key to the on position, you're supposed to hear clicking. it's your aic setting up or whatever.
Old Nov 7, 2005 | 07:41 PM
ambystom01's Avatar
I'm not sure if I've ever heard a click, but thats just cause I don't pay that close attention.
Old Nov 7, 2005 | 08:56 PM
ROCK's Avatar
Again clicking is normal. IF you think there is a problem, check for vacuum leaks. Next reset ECU by disconnecting battery. IM does not cause CEL.
ROAD/RACE
Old Nov 7, 2005 | 09:11 PM
Boeturbolancer's Avatar
you're idling to high from what i'm seeing. The idle being that high will trip that code. Turn the Idle Bleed Screw in, clockwise, until the idle is back to 600-700 rpms. Then the code should go off shortly after that.
If it doesn't go off let me know but that should take care of that.
Old Nov 7, 2005 | 09:22 PM
ambystom01's Avatar
K I'll give that a try tomorrow, thats what I thought it was, but I didn't want to d!ck around with my car again.
Old Nov 7, 2005 | 10:08 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Doesn't the IM have a gasket? Is it possible that he caused a leak in that when installing the IM? if so, easy fix, but this is a shot in the dark in case the other suggestions don't work.
Old Nov 8, 2005 | 12:30 PM
TeamAccolade's Avatar
check ur sensors and plugs...
Old Nov 8, 2005 | 02:14 PM
akasirlancerlot's Avatar
plz check the vaccum lines and all the connections and send a check payable to pete lopez to po box..... wait nevermind. ok yes im lame, but at least i try gl amby
Old Nov 8, 2005 | 02:16 PM
ambystom01's Avatar
I turned down the idle screw, hopefully this will solve the problem.
Old Nov 8, 2005 | 03:12 PM
Nad1370's Avatar
It doesn't matter if you turned the screw down. If you have a vaccum leak, the idle will still be high.
I'm not sure on a Lancer if you guy's have 2 hoses going in the AIC. He might have switched them.
I would run the car and spray carb cleaner around the manifold or hoses to find the leak.
Old Nov 8, 2005 | 03:19 PM
ambystom01's Avatar
The idle went down, it was originally around 1100-1200 now its like 700-600. I'm gonna wait and see if thats why the CEL came on or whether its something more indepth.
Old Nov 8, 2005 | 03:42 PM
man amby ur car is giving yah a lot of headaches.
Old Nov 8, 2005 | 03:47 PM
ambystom01's Avatar
My car is like a woman, it only began giving me problems when I decided to fu<k around with it.
Old Nov 8, 2005 | 04:01 PM
Alchemist's Avatar
Everyone take notes- this is why you don't fawk with the BISS! I hope you get this figured out. What exactly is the code that you get (if it comes up again....)
Old Nov 8, 2005 | 04:13 PM
ambystom01's Avatar
Something like "idle air control", basically something to do with idle air.
