IM and cel
Old Nov 8, 2005 | 04:41 PM
  #31
WADADLIG_OZ's Avatar
Originally Posted by Alchemist
Everyone take notes- this is why you don't fawk with the BISS!
Jeez I hope not...
The mechanic adjusted mine to get the idle right on my cam. The idle is much better now after the Ecu had some time to learn but if I reset it it goes back to the little rough idle.
WADAD
Old Nov 8, 2005 | 04:51 PM
  #32
Alchemist's Avatar
I've never touched my BISS and my idle is perfect at 680-730. I'm curious about that- PM me if you wanna discuss.
Amby- I was hoping for a code number Pxxxx or something similar. If you have to check it again, let us know
Old Nov 8, 2005 | 04:55 PM
  #33
ambystom01's Avatar
What exactly is the BISS? I'm gonna talk to my mechanic and have my codes checked again as it may have simply been the cat code coming up again.
Old Nov 8, 2005 | 05:53 PM
  #34
Boeturbolancer's Avatar
BISS is same as Idle Air Bleed Screw on the lancer. Some use that term from older dsm's and in some books it just calls it the Idle Air Screw. All ways of saying the same thing.
The screw you turned was what they were talking about. Your mechanic must have turned it up for some reason or it got turned somehow. Either way you're idle range is back in focus so you shouldn't get that code anymore.
If you do then check for some leaks but since the idle was controllable it wouls seem that a vacuum leak isn't likely. If you have a chance to get ahold of a pressure/vacuum gauge hook it up real quick under the hood and read idle vacuum. 18-21hg is average idle range on stock cams.
Old Nov 8, 2005 | 06:06 PM
  #35
ambystom01's Avatar
K will do.
Old Nov 28, 2005 | 05:02 PM
  #36
ambystom01's Avatar
Ok I adjusted the idle screw until the idlei was at a lower level (around 700) and installed the cel fix, and the CEL came back today after about 300 km of driving. Anybody have any idea on what could still be the problem? The mechanic thinks its the IM, but I can't think of what could be going wrong, maybe a leak?
Old Nov 28, 2005 | 07:33 PM
  #37
Alchemist's Avatar
what's the code number?
Old Nov 28, 2005 | 07:37 PM
  #38
ambystom01's Avatar
Not sure what the exact number is but I believe its still that same "idle air control" code. It doesn't make any sense, it came on today while I wasn't idling, I was going like 40km/h.
Old Nov 28, 2005 | 07:41 PM
  #39
sweet_bucket22's Avatar
probably have a bad idle speed control motor. May need a new one?
Old Nov 28, 2005 | 07:43 PM
  #40
ambystom01's Avatar
I hope not since I've already spent 5000$ getting this damn motor fixed.
Old Nov 30, 2005 | 03:34 PM
  #41
vietxscapeD's Avatar
i remember the days of my CEL light coming on... actually, i think it's still on. My CEL light has been on for so long that it the light pretty much burned out.... O_o?
Old Nov 30, 2005 | 05:33 PM
  #42
dan00780's Avatar
i am having a similar problem, i cant remember the code its throwing but i have been told by the dealership and autozone that its the idle air control code. i idle fine with my A/C off but if i put it on i get a vibration in any drive gear, neutral and park are fine. i have had this problem since the start of summer and i have been fiddling with all 3 of my idle screws, i had it set to idle real high because it seems when i go ito a drive gear the rpm drops and starts vibrating but if i keep it high it wont drop 2 far and the vibration is tolerable. now i dunno what to d, i remember that i cleanre my throttle body with carb spray/throttle body cleaner - u think that killed my sensors? soemone help me please
Old Nov 30, 2005 | 05:38 PM
  #43
ambystom01's Avatar
My cars going into the mechanic tomorrow, hopefully he can shed some light on this.
Old Nov 30, 2005 | 05:44 PM
  #44
dan00780's Avatar
gr8 -- let me know what he says
Old Dec 1, 2005 | 02:11 PM
  #45
ambystom01's Avatar
Hahaha I got good news from the mechanic. The code being thrown is not the idle air control code, its the cat code. Turns out he put the mechanical fix on the header and not on the 2nd O2 sensor, so hopefully everything is fine and dandy now.
