Custom Grounding Kit
Old Feb 22, 2006 | 01:16 PM
05ES's Avatar
I've seen many people on here make custom grounding kits.
When they do this is it just a bunch of heavy guage wire?
I figure yes because it's just suppose to distribute the electrical current but I don't know for sure.
Any advice would be great
Old Feb 22, 2006 | 03:08 PM
Blacksheepdj's Avatar
Basically, you summed it up. Heaviest gauge you can afford, and some high-quality ends. Cut to length and install. And then HOPEFULLY you notice a difference (I never did).
Old Feb 22, 2006 | 04:25 PM
newbiewonkenobe's Avatar
did your car still shock you with the grounding wire?
Old Feb 22, 2006 | 08:27 PM
05ES's Avatar
any ideas where to get a good round center metal piece to attach the wires to?
Old Feb 23, 2006 | 10:05 AM
Why? Just daisy-chain it. That's how many systems work.
Yes, your car will still shock you. That's a different ground system.
Old Feb 23, 2006 | 11:29 AM
05ES's Avatar
Anyone got a diagram on where to daisy chain it to and from then. Never actually seen this done. Thanks
Old Feb 23, 2006 | 01:12 PM
SLVROZ_03's Avatar
I've post the steps in a couple threads; just do a quick search... And no, the grounding kit you're wondering about doesn't stop the "shock treatment."
Old Feb 23, 2006 | 03:04 PM
blacklancerr's Avatar
there's a lot of threads. run a search like ^^^ said.
here's a diagram : https://www.evolutionm.net/forums/at...chmentid=80906
Old Feb 23, 2006 | 06:39 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
You have to keep in mind that a grounding kit only increases performance if it is tested on a dyno. The professionals who do this try multiple configurations, testing each one on a dyno to determine which configuration gives the best results. Even then, they are just squeezing the last 1% of the horsepower they can get. Although I can't vouch for how it helps a stereo system, don't expect any horsepower gains from our Lancer, even if you do spend a day and hundreds of dollars dyno tuning it.
Old Feb 25, 2006 | 03:16 PM
AndrewMMueller's Avatar
Lightbulb
Hey, just wired up my Ground kit today. made a custom negative battery bolt on terminal out of a chunk of an old kitchen sink.. a plasma cutter.. and some bolts and a new F-ed up drill bit.
now heres the question... got about 80 feet of Red OFC Stinger 1/0 gauge wire hangin around and the same thing in 4 gauge...
go with the 4? go with the 0/1?
cause i mean cmon.. 0/1 is huge ****... were talkin 200+ ampers capability, how much does the car REALLY need that...
Old Feb 25, 2006 | 03:48 PM
mitsuozboi's Avatar
I read in a past thread you want 0 gauge... if you cant get it then either 1 or 2. someone can correct me if im wrong.
Old Feb 25, 2006 | 04:53 PM
im more curious as to the quality of ground is really needed if the sell the car minus the grounds anyways... i think ill use 4... 0 is like an inch thick... overkill me thinks... i just dont wanna cheap out where i shouldnt.
badev0
Jun 12, 2015 09:00 AM
flo2877
13
Dec 28, 2005 06:57 AM
Iamkar33m
Lancer Engine Tech
14
Oct 29, 2004 12:11 PM
keviin
Oct 6, 2003 02:20 PM
CTS 1273
Mar 7, 2003 12:01 AM
