Lancer 03 OZ Rally Compatitble rims?
Old Apr 21, 2006 | 10:18 PM
JoshuaWong's Avatar
Where can I find 17' rims that fits 03 OZ Rally? Like Rays, Enkei... etc
Old Apr 22, 2006 | 12:16 AM
twardnw's Avatar
new to the internet?
try searching...
pretty much any tire place would have them. Just make sure they have a 4x114.3 pattern. And you'll probly be better off looking for 17" rims, 17' might not fit...
www.tirerack.com
www.victoriatire.com
www.google.com
www.froogle.com
Old Apr 22, 2006 | 01:02 AM
elpedro's Avatar
The best option for the 03-04 OZ Rally (at stock height down to Eibach level) is:
17x7 rims
4x114.3 lug pattern
40mm offset
215/45/17 tires
If you go any wider on the rims and they will rub.
If you go any thicker or wider tire size they will rub.
If you go any other offset they will most likely rub.
and finally...
If you go any lower profile tire size you will get that cheap-o "too much space around the wheel" look.
enjoy your new wheels, search better next time.
this has been discussed many times in a thousand threads...
Old Apr 22, 2006 | 07:12 AM
ThunderOZ's Avatar
with the 215/45 tire wont you need to get your speedo recalibrated? I thought the best match up was a 205/40 series tire...
Old Apr 22, 2006 | 07:54 AM
Wallesasuaz's Avatar
yes, best size is a 215/40/17. That's what i'm running now and my car is dropped on TEIn Basics. No Rubbing at all and the gap between the fender and wheel is sweeeeeeeet.
I say 215 caue they're nice and wide w/ an aggressive look. 205, is too narrow, basically will look like the stock ones!
Old Apr 22, 2006 | 08:28 AM
ThunderOZ's Avatar
So is it 205/40/17, 215/40/17, or 215/45/17 tires on a 17X7 rim thats the best for the OZ?
And will everything need to be recalibrated?
Old Apr 22, 2006 | 08:54 PM
ThunderOZ's Avatar
bumpity bump bump
Old Apr 23, 2006 | 08:33 AM
Silens's Avatar
Here is a nifty tire calculator that will tell you how much your speedo will be off http://www.net-comber.com/tirecalc.html
mitsubishilover
Sep 5, 2013 09:18 AM
bkamp
02-03 Lancer Show / Shine
Jul 21, 2011 06:38 AM
lloyd03oz
Lancer Aftermarket Forced Induction Tech
Apr 3, 2011 09:52 PM
lloyd03oz
Sep 2, 2010 04:35 PM
lloyd03oz
Sep 2, 2010 04:16 PM
