Engine prob..
Old Apr 22, 2006 | 06:08 PM
xchanhxlex's Avatar
Post Engine prob..
Everytime I accelerate i hear a squeeking noise from the engine or sum place and then when i acceleration some more it goes away....and everytime time the needle gets below 30 mpg...it sqeek...should i be worried or wat should i do.
Old Apr 22, 2006 | 06:17 PM
ambystom01's Avatar
It could be the dash, the suspension or a real problem. Mine squeaks but its the dash and the suspension. Does it squeak in the rain?
Old Apr 22, 2006 | 06:38 PM
ThunderOZ's Avatar
My engine does the same thing under slow acceleration...~30-45mph... But if I give it a little more gas it goes away...
Old Apr 22, 2006 | 06:43 PM
Shingen's Avatar
Mine is starting to do the same thing. You might want to check your breaks.
Fox
Old Apr 22, 2006 | 06:53 PM
ThunderOZ's Avatar
Fox: do you mean brakes? Mine are sqealing now, I think theyre getting stuck against the rotor or sumthin, but my engine still whines/sqeals....
-Merc
Old Apr 22, 2006 | 07:30 PM
Blacksheepdj's Avatar
Squeeking - fan belt? That's the traditional answer from US cars... Maybe they've gotten loose over time?
Old Apr 22, 2006 | 08:04 PM
ThunderOZ's Avatar
then why dones mine go away as soon as I give it a little more gas?
Old Apr 22, 2006 | 08:19 PM
RumbleCam's Avatar
my belt is squeeling when i first start my car then when i rev it up it goes away. only does it cold. i checked the tension and there is lots i dont knwo why its doing it but it is.
Old Apr 22, 2006 | 08:26 PM
Moofahsah's Avatar
replace the belt
Old Apr 22, 2006 | 08:30 PM
RumbleCam's Avatar
ya know i should have thought of that...
Old Apr 22, 2006 | 10:57 PM
primo16's Avatar
I had this problem when i first got my car last may. i sprayed some belt ease ( something like wd40) on my alternator belt and after a few applications over the course of a few days the sound went away, for good.
Old Apr 22, 2006 | 11:01 PM
comatose721's Avatar
my fans aren't attached to any belts
Old Apr 23, 2006 | 08:36 AM
Tightens when it spins, I'd assume. Or just moves fast enough to not make the noise.
Old Apr 23, 2006 | 08:45 AM
BensLancer's Avatar
mine was doing that too, but it stops when I accelerate and when I degrease my engine and spray engine dressing all over. It has to be the belt, but I can't take my car to get that stuff yet until I can get my hood fixed! NC sucks!
Thriver's Avatar
yea its the belts. same happens with me at the same speeds so i believe its the belts because i checked the breaks and those are fine. Anyone know when to change ur alternator and power steering belts.
