whats wrong?
Old Jun 7, 2006 | 11:18 PM
pinay8utterfly's Avatar
whats wrong?
There are a few times where i have trouble starting up my car.
When i try to start it up i have to rev the engine a bit to make it start.
Is there something wrong with my starter or something else?? I really need some help
anything helps Thanks!
Old Jun 7, 2006 | 11:34 PM
twardnw's Avatar
umm, try and clear that up a little. If you're 'revving' the engine, it has to have been previously started.... Any CEL? Funny noises? How long has it been occuring? What's the weather like? Does it change with different types of weather?
Old Jun 8, 2006 | 09:35 AM
Wallesasuaz's Avatar
yes please give us more details...
how many miles on your car? Have you had your fuel line cleaned? Injectors could be dirty?
if you have alot of miles on it, timing belt may be off by a bit. Could be alot of things... let us know...
Old Jun 8, 2006 | 10:12 AM
Blacksheepdj's Avatar
It's not the starter. If you're revving the engine, the car has already started. So it's more about your idle on startup.
Old Jun 8, 2006 | 12:14 PM
Walkingchaos's Avatar
throw a thing of Lucas fuel and injector cleaner in there. Stuff is cheap and works great, if that doesnt clear it up you may have to adjust your idle a bit, not too hard to do.
Old Jun 9, 2006 | 08:08 PM
BensLancer's Avatar
Make sure your battery is good too! My wife's car had a problem that sounds just like what you are describing!
Old Jun 11, 2006 | 02:00 PM
i just got the battery like 4 months ago so i don't think that should be the problem
i have about 70xxx miles on it. I checked the timing belt but its still doesn't look like anything is wrong with it either. I talked to a few people and they say its the starter. I mean it could be
at first when i try to turn on the car it looks like the battery isn't charged all the way but i kow its not the battery
basically i have to press on the gas a few times to acutally turn on the car
Thanks guys fro helping.
Old Jun 11, 2006 | 02:07 PM
comatose721's Avatar
if it was the starter the car wouldn't start normally. it would make a high pitched squeeling sound if it wasn't engaging with the flywheel OR the solenoid wasn't engaging. starters are EXTREMLY easy to diagnose. it you are 70k do a tune up first. change the plugs, new air filter, inspect timing belt for cracks/wear/dry rot/etc, check drive belts, new oil, injector/full fuel system cleaner, change the tranny fluid/gear oil (i know this has nothing to do with start-up but you might as well get it all in one shot), PCV valve, and clean the EGR system out....after that, if you still have problems, look deeper into things. you may need to up the idle OR the ISP sensor or TP sensor might be going bad.
EDIT: are you pulling a CEL? if so that is crucial to have the code pulled. ALSO i forgot to mention inspecting the coil packs and plug wires to see if they need to be replaced.
mark
bluedevil06
Site Feedback / Suggestions
Jul 11, 2011 10:08 AM
yoster4
Sep 19, 2010 08:02 PM
Aven
Aug 21, 2009 11:06 PM
Skott2k
15
Mar 26, 2009 09:55 PM
Optimus
Lancer Troubleshooting
13
Nov 8, 2003 09:19 PM
