drilling into carbon fiber
I drilled through my cf trunk just a couple days ago... Use painters tape on each side as said above- to prevent splintering. Use a nice sharp bit and go slowly. its pretty much just like drilling through straight fiberglass.
use the tape trick on both sides not just finished side, and don't just use a drill bit. make a pilot hole much smaller than your than your final hole, then use a step drill aka uni-bit to carry your hole size up. have some two part epoxy or resin on hand to seal what gets drilled through. good luck enjoy your new parts
ch47god- thanks for adding the pilot hole first. I did forget to mention that. haha.
I never thought of epoxy or resin the holes that you drill. is that something that really needs to be done?
