Got a CEL P421
Old Jul 29, 2006 | 10:19 AM
gregivq's Avatar
Blacksheepdj, that would be pretty nice but I don't think I know as much as Boe, Hobie, Alchemist, Rhyzin, etc.
Crypto, just use the first link I gave you and read.
Old Jul 29, 2006 | 10:27 AM
crypto's Avatar
Former Vendor
yeh ive read over it, i cant read anything really bad about the ecu flash. other than problems shifting in manuals. i should be ok in my auto.
when the light comes on again i will take it down to the dealership, get it sorted, and report back with any gains and or set backs from it.
Thanks for the help
Old Jul 29, 2006 | 01:45 PM
yellowlancerOz's Avatar
just remove the cat....we dont have emission in FL
Old Jul 29, 2006 | 02:02 PM
crypto's Avatar
Former Vendor
yeh but wont that take away my back pressure? i how would i remove it? just knock the inside of it out, or would i have to get a test pipe?
Old Jul 29, 2006 | 02:09 PM
ambystom01's Avatar
It's the first cat I think, you can just buy a header to replace the exhaust manifold.
crypto's Avatar
Former Vendor
also will the CEL stay on if i get rid of the cat?
Old Jul 29, 2006 | 02:11 PM
crypto's Avatar
Former Vendor
i dont have enough money for a new header. i will just go down to the mitsu dealership and have them flash it and put in a new cat.
Old Jul 29, 2006 | 02:15 PM
ambystom01's Avatar
Personally I hate the flash, I'm actually buying a new ECU just to get rid of it.
Old Jul 29, 2006 | 04:29 PM
crypto's Avatar
Former Vendor
ok. what has happened since you got it? performance loss or anything of that sort?
would i be able to get them just to replace the cat and not reflash?
Old Jul 29, 2006 | 06:32 PM
Centrylancer's Avatar
yeah, its the front catalytic convertor...
had the same thing happen to me... its in their system, it was a recall.
Old Jul 29, 2006 | 06:55 PM
crypto's Avatar
Former Vendor
yeh but what are the drawbacks on getting it done though???
the search isnt working for some reason
Old Jul 30, 2006 | 04:21 AM
Gr33dyMitsU's Avatar
Have you tried the CEL eliminator from RRM? install that where your 2nd o2sensor is.
And reseting your ECU might not fix the problem because I did that myself when I had a CEL problem. The CEL light itself went away for a few days but came back on.
Check for exhaust leaks, Your o2 sensor might be bad, or like someone stated earlier check your cat.
Old Jul 30, 2006 | 01:37 PM
crypto's Avatar
Former Vendor
well its the recall code, so i most likely need to go for the recall, i just dont wanna do it if there are major drawbacks
Old Jul 31, 2006 | 10:03 AM
Alchemist's Avatar
I'm having trouble with the search results links, too, but here you go: https://www.evolutionm.net/forums/sh...ighlight=P0421
Since there's a recall on an item it is illegal for the dealership to deny you service for that item. They can however void parts of your warranty for mods. I'd try the aforementioned 2nd cat O2 sensor spacer to see if that doesn't give you the temp difference your ECU is looking for and letting the car warm up fully before driving is a good idea in all cases.
Old Jul 31, 2006 | 10:27 AM
crypto's Avatar
Former Vendor
the only mod i have is an intake, so its not like my car is under alot of strain. I will take my car to the dealership tomorrow and have them look at the cat and get a reflash.
