new iridium spark plugs
Old Aug 9, 2006 | 12:57 PM
WangMan's Avatar
After I installed new iridium spark plugs, I noticed my car idles at about 700 rpms. Is that normal? cause it feels a bit low. Also, on a couple of occasions it has dipped even lower for a second and nearly caused my lancer to stall. Do I need to regap my plugs to a larger or smaller gap?
Old Aug 9, 2006 | 01:04 PM
ambystom01's Avatar
Mine idles at like 600 RPM if that helps. Not sure why it would dip like that, did you put the AC on?
Old Aug 9, 2006 | 01:05 PM
Danno's Avatar
Copper Plugs > Iridium for the lancer. Save your money. But yes that is normal.
You will find that they will need cleaning/replacing after about 2000km (just a FYI)
Old Aug 9, 2006 | 01:15 PM
LancerAdam's Avatar
Save the money and just put regular plugs in. Did not notice a diffrence when i put them in my car
Old Aug 9, 2006 | 01:45 PM
Chizilds's Avatar
Nor did I
Old Aug 10, 2006 | 08:50 AM
tmhamer's Avatar
the only thing i really noticed after i had my iridium plugs installed was a definite increase in performance over stock
Old Aug 10, 2006 | 08:53 AM
ambystom01's Avatar
Wow only thing I noticed was about 70$ out of my wallet and a slightly better idle, probably caused by the fact I got my oil changed at the same time.
Old Aug 10, 2006 | 09:00 AM
Chizilds's Avatar
LOL thats what I was going to say. I got them done at the same time as my oil change as well... perhaps I got 2mpg better in fule economy from the plugs as well...
Old Aug 10, 2006 | 09:12 AM
Danno's Avatar
That wasn't an increase in performance, it was your brain hiding the fact that you just wasted money on a useless mod and instead of letting you feel crappy about it, it saved face with yourself and let you think your car was faster. The same goes with spoilers, window tint and exterior lighting.
Old Aug 10, 2006 | 09:16 AM
ambystom01's Avatar
Don't forget about grounding kits, even though I own one I have no problem admitting it's done diddly squat.
Old Aug 12, 2006 | 07:01 PM
WangMan's Avatar
Yea I haven't noticed any performance difference either. They were a waste of money. My rpm's haven't dipped below normal since making this post, so I suppose if there ever was a problem, it fixed itself. From now on though, I'm definitly sticking with copper.
Old Aug 13, 2006 | 11:39 AM
guwapings's Avatar
I just changed mine and having the same problem with the idle but with that problem comes a great difference when changin shift.... the car feels much SMOOTHER when i pull the car to a higher rpm when driving....
Old Aug 13, 2006 | 12:10 PM
newbiewonkenobe's Avatar
I tend to agree with TMHAMMER.... I just installed my (free - good thing wife works at autozone!) iridium ngk's today. I'm not experiencing any idle problems, although at initial startup I noticed the car idled silently - nice. I haven't driven too much yet, but after my first drive idle seems normal (not silent however). I think there was a teeeny bit of performance gain. I was also thinking I had some smoother shifts and slightly better acceleration.
Old Aug 13, 2006 | 02:15 PM
Chizilds's Avatar
I must have bought the wrong ones then...
Old Aug 14, 2006 | 12:49 PM
LancerMarita's Avatar
I installed the NGK Iridium IX's at about 56k, and I noticed a difference. The main change was that I had a lot better response with acceleration.
