Water Leak List Thread!!
Old Jul 26, 2007 | 11:18 PM
superfly78209's Avatar
I'm bringing this back to life again to see if anyone has had any new experiences. It's been raining everyday here in San Antonio, Tx for the past 2 months and my drivers side floor board is now soaked. First it was my passenger side floor board and after a lot of caulking and crap I finally slowed the leak down on that side but it's still managing to come through. Any advice guys? If you go to autoconsumer guide and look at the common problems with the lancers you will see 3 water leaks. Apparently Mitsubishi isn't too concerned about water getting into the car. I guess thats how they are in Japan.
Old Jul 26, 2007 | 11:21 PM
here's the previous thread this came from https://www.evolutionm.net/forums/sh...ght=water+leak
Old Jul 26, 2007 | 11:22 PM
coal's Avatar
Ok I have a small water leak on the top of my windshield. It leaks right down the middle, a very small leak.
Old Jul 26, 2007 | 11:37 PM
Yea, see my leak comes from somehwere behind my dash, your lucky you can see yours. Get some Windshield sealer and seal it up from the outside.
Old Jul 26, 2007 | 11:40 PM
bene's Avatar
find the leak and fix it?
Old Jul 27, 2007 | 12:01 AM
kungfugirl's Avatar
EDIT: My appoligies if i offended anyone with my visceral and apparent innapropriate response. Good luck finding your leak i will let you know if i come across any on my vehicle.
Old Jul 27, 2007 | 12:03 AM
Dude it's really not that easy. There are so many seams on the firewall and one could be broken. Also if it's coming from behind the dash you probably have to pull the dash out to find the leak. I got about half way into the project and realized how much work it would actually take. Water leaks aren't easy to find at all and if anyone has some clue of where their problem was it could help. Also does anyone know specifically where the ac drain hose is?
Old Jul 27, 2007 | 12:05 AM
Yo Kungfu , I pulled my **** carpet, took off my glove box, took out all other dash pieces and still couldnt find the leak. I've done water testing out of my *** and your the n00b who can nievely say that it's not that hard.
Old Jul 27, 2007 | 12:35 AM
kungfugirl's Avatar
edit.
Old Jul 27, 2007 | 12:43 AM
lol dude i was half joking. but please don't say anything you don't understand about.
Old Jul 28, 2007 | 12:49 AM
coal's Avatar
Well if the leaks are JDM maybe I should just leave it alone!
Old Jul 29, 2007 | 01:05 AM
Ash_Lancer's Avatar
My carbon trunk
I have a leak in my trunk, I have the VIS Carbon fiber trunk, and on the inside the left and ride sides get a little wet, I don't know if I need new black lining or whatever its called, going to try and put a sysytem in my car but afraid it will get damaged so if anyone has figured it out let me know thanks
Old Jul 29, 2007 | 05:57 PM
thector1's Avatar
I have the same problem. Its not coming from the bottom cause got it all dry againg and didn't use the car for a week, it's been raining, and its soaked again. If you find a lead for your leak, please PM me.
Old Jul 30, 2007 | 07:45 AM
joeyfingers's Avatar
ya i have had a water leak in my 04 lancer since i had it.my car flooded like 3 times last year mine was pretty bad to it was all under my carpet and when you pushed on the carpet you could hear it sqwishing around.it seemed to all gather were the two levers are for your trunk and gas tank are and then procedded to go under my drivers seat and into the back seat pretty much the whole driver side of my lancer was flooded
Old Jul 31, 2007 | 10:55 PM
Maybe my trunk is leaking too. When I pulled my rear seats out awhile back there was some moisture in there. Not sure where from though. These lancers are crazy.
