Closing in on 40k miles
Old Oct 3, 2006 | 06:45 PM
LancerOZ Boy's Avatar
Ok so i am getting close to 40k. I know around there i should change my timing belt. But is there anything else that needs to be serviced aswell? Also its about time to get an oil change. What type of oil should i run? Just whatever it takes or synthetic? Does it really matter or is it just my preference?
Old Oct 3, 2006 | 06:47 PM
mitsuozboi's Avatar
if you have synthetic stay with it. if not switch to it. Timing belt is more around 70k I thought.
Old Oct 3, 2006 | 06:54 PM
atilla's Avatar
AFAIK i was the first person to do the timing belt on my car, i'm the second owner and i did it at 103k. it did need it by then though... the old one was pretty FGFU. you can change it if you want, but at 40k i don't think you'd need it. the whole process wasn't THAT bad, it's that damn motor mount that really was a pain. it helped that i had someone who knew exactly what they were doing (lanceradam) showing me exactly what needed to be done.
i run 5W30 mobil 1 in my car. getting it free at work helps when it comes to picking synthetic over regular oil.
Old Oct 3, 2006 | 06:56 PM
So if i dont need to change my timing belt is there anything i need to worry about soon or is it all far away from now?
Old Oct 3, 2006 | 06:59 PM
mitsuozboi's Avatar
just do a routine tune up. change fluids. check belts. rotate tires.. all that good stuff.
Old Oct 3, 2006 | 07:09 PM
lancer2show's Avatar
60k timing belt
Old Oct 4, 2006 | 10:03 AM
SLVROZ_03's Avatar
^^^per manufacturer, but don't worry about it now. Check above for the neccessaries...
Old Oct 4, 2006 | 10:46 AM
Punkskalar's Avatar
Drain and Refill automatic transmissions every 30K if you can help it...
Old Oct 4, 2006 | 01:42 PM
Blacksheepdj's Avatar
Change all these:
Spark plugs
Tranny fluid
Brake fluid
Coolant
Intake filter
Old Oct 4, 2006 | 07:07 PM
Well i just got the brakes serviced recently and i just put on my short ram a few weeks ago so that knocks those off
Old Oct 5, 2006 | 10:18 AM
Does "brake service" include new fluid? Not always...
DanielM
Apr 13, 2016 02:13 PM
ethan169
Nov 12, 2011 11:28 PM
Lancer GT
Lancer Tranny/Drivetrain Tech
11
Feb 5, 2010 02:18 AM
Ltdanish07
Oct 27, 2008 08:03 AM
pearlwhiteoz
19
Sep 27, 2002 08:58 AM
