Mods for NA (my experiance)
Old Mar 19, 2007 | 08:47 AM
  #166
LancerAdam's Avatar
PS I want a turbo that spools quickly. I do not care about top end just want to get out of a corner as quick as I can
Old Mar 19, 2007 | 09:22 AM
  #167
neilschelly's Avatar
Every Lancer I see at an autocross, except for some Evos lifts the inside rear corner on a turn. So yes, it will have better traction in the rear on cornering and that will lead to less oversteer with a stronger front bar, but it will keep the car better planted on the ground and able to corner harder too.
In FWD, you're far better off using your left foot to brake while cornering to get the oversteer you're looking for. Don't snub your nose at a front bar just because it'll counteract that oversteer a little. It will keep the dynamic suspension alignment all around the car more controllable, limit the lean of the car, etc.
Every top autocrosser I've ever asked, especially in FWD cars, says it's one of the most important mods you can get.
-N
Old Mar 19, 2007 | 10:43 AM
  #168
drucea's Avatar
You sound all set for turbo. I think the one from the RRM kit spools quick enough. And their kit looks damn good. And when you get the pistons and rods you will be able to turn the boost up. And The camshaft sounds good too. Are you going with RRMs or RPWs?
Old Mar 19, 2007 | 11:02 AM
  #169
LancerAdam's Avatar
Not sure yet. I'm in the learning faze at this point.
Old Mar 19, 2007 | 09:23 PM
  #170
ROCK's Avatar
Remember, RRM is the only complete kit! Haha. Love saying that!
ROAD/RACE
Old Mar 19, 2007 | 09:44 PM
  #171
LancerAdam's Avatar
And that is why I talked to you!
Old Apr 12, 2007 | 06:59 AM
  #172
LancerAdam's Avatar
So I ended up getting a really good deal on the upgraded front sway bar. Less than $100. I tell you it was a PIA to install the cross member almost has to come out! I can feel the difference in driving n off ramps the car is a bit more predictable.
Old Apr 12, 2007 | 07:12 AM
  #173
mtags24's Avatar
If you don't care about top end maybe you should go with a t-25 turbo. RRM does them in the stage 0 and non-intercooled kits i believe. that should hit full boost sooner than the 16g. i would ask Rob about it, maybe save some $ too
Old Apr 17, 2007 | 10:58 AM
  #174
LancerAdam's Avatar
We are in conversation about it! It will be after this race season
Old Apr 17, 2007 | 11:24 AM
  #175
Yes, it wouldn't be fair if he dropped out of FSP because I wouldn't get the same satisfaction out of taking it from him. ;-P
-N
Old Apr 17, 2007 | 11:27 AM
  #176
LancerAdam's Avatar
Got the jacket... Guess we will see this weekend!
Old Apr 22, 2007 | 06:37 PM
  #177
LancerAdam's Avatar
Life has taken a change, think I am going to sell off my Jic's.
Old Apr 23, 2007 | 08:46 PM
  #178
LancerAdam's Avatar
First autocross went well. I have the new front sway bar in there and I can say I did feel a difference. the Car felt a bit more balanced. I did still lift the inside rear tire. Some have said it may even need to be bigger. I tell you I am never doing that job again.
Old Apr 24, 2007 | 04:49 PM
  #179
atilla's Avatar
still planning on switching to the megan coilovers?
i don't know if i will be able to make it to the second event at loudon, but i will definitely get to the events on devens. hopefully by then i can get my own helmet, i can't wait to race again.
Old Apr 24, 2007 | 05:55 PM
  #180
dewood*'s Avatar
i would love to see some more pix or videos of your car and mods
