noooooooooooo not the honeycombs
Old Mar 3, 2007 | 06:46 PM
DickMorgan's Avatar
crap... i dont know how this happened at all, especially since i was careful not to even touch them, but when i was installing the cold air intake, i was having trouble with the MAF bolts, so i just ended up taking off the whole box to work on it outside the car, and before i put it in , i noticed a few of the honeycombs were bent. just a couple in the middle
Now how bad did i screw up my car???
If i do need to get a new one, can i just buy one at any local autozone or pep boys or do i need to go to a dealership.
Can i just leave it alone???? CEL isn't coming on.......i reset ECU and gave proper time to adjust and drove it around for a bit, i'm thinking maybe i'll reset it again tomorrow morning cause i did gun it for a little bit to feel the extra power lol.
so how bad did i f*ck up guys?? be honesT
p.s. i tried searching but after 4 pages of reading threads , i got fed up and decided to ask myself
Old Mar 3, 2007 | 07:22 PM
drucea's Avatar
Oooooh you're really f---ed now. J/k I really don't know what happens if you bend it a bit. I guess it's ok if theres no CEL and it drives fine. But if you do notice it screwed something up, I would check with the junkyards to find a recked lancer (same trans. type as yours) and get it off their first cause the dealer will charge out the ***.
Old Mar 3, 2007 | 07:29 PM
otter's Avatar
EvoM Administrator
Out the *** = $238, just FYI.
Old Mar 3, 2007 | 07:45 PM
DickMorgan's Avatar
oh F*ck. !!!!!! yeah just a couple of the honeys are bent, but the majority of them are cool.
I will def. go see a junkyard first if i notice anything wrong with my ish, screw going to a dealership
Old Mar 3, 2007 | 07:48 PM
EvoRecordSetter's Avatar
bend them back. take needle nose pleyers and straighten them out.
if its the same kind of honeycomb thats on DSM MAF. i bent a couple and just straighten them back out.
hope it works for u.
Old Mar 3, 2007 | 07:55 PM
drucea's Avatar
I'd recommend not using needle noses cause they have ridges for grip which could be harsh on the fins. Are they just bent a tiny bit or pushed down hard? I would just leave them until something happens with it.
Old Mar 3, 2007 | 08:34 PM
crypto's Avatar
Former Vendor
yeh i had the same thing. one of the honeycombs was slightly bent. i just used a needle nose plier and adjusted it. turned out fine.
Old Mar 3, 2007 | 08:45 PM
04lancerEsGuy's Avatar
You are fu(ked....however; just cross your fingers and wait until used MAF shows up on ebay. As soon as you see one............jump on it
Old Mar 3, 2007 | 09:01 PM
SteVenQDZ's Avatar
same thing happen to me when i was trying to install the air intake... but i didnt mind and put it all back together... and it runs right didnt see to have any problem
Old Mar 10, 2007 | 05:18 AM
WADADLIG_OZ's Avatar
I wouldn't use a needle nose pliers.
Get one of those small screw drivers (usually silver) that you can use for glasses or small screws and gently and I mean gently straighten out the honey combs.
This happened to me also when I installed my CAI. Don't try to get too perfect an edge because if they are bent there is only so much straightening you can do.
Once you try to make the edges perfect you will likely break the honeycomb piece itself.
See if you can take a pic and post up.
WOuld be easier to tell how badly damaged it is.
WADAD
Old Mar 10, 2007 | 05:25 AM
SnapDragun's Avatar
They make some needle nose pliers that does not have the grip teeth. I picked up mine from radioshack a while back.
Old Mar 11, 2007 | 09:39 AM
lncrphish's Avatar
Same thing here man. use it and see if it works before you start freaking out.
Old Mar 15, 2007 | 07:41 PM
Evo666's Avatar
same thing happened to me i just used a needle to try to straighten them out the best i can
Old Mar 15, 2007 | 09:02 PM
grubiaco's Avatar
straighten them out the best you can. If it gives you problems you are going to have to buy a new one. If anything you can get an evo one from someone that went full ems.
