Props to Progress!!!
Old Mar 7, 2007 | 12:51 PM
subydrift's Avatar
So I just installed my Progress 19mm rear sway bar and that was the easiest install I have ever done! It was even easier then changing my oil!! Took a total of about 25 minutes to get on there! If anyone has not done the sway bar upgrade, it makes an enormous difference in handling!! I have all stock suspension except for this bar and the difference is night and day!
So good job to Progress for making a great product! And the best part is that Progress supplies directions specific to the vehicle instead of a generic set of directions. And, they even give you the factory part #'s for the perches if your putting this on an ES model. Its awesome!!
Old Mar 7, 2007 | 02:27 PM
Blacksheepdj's Avatar
And props to RRM for designing the bar and working with Progress to get you all that good stuff.
Old Mar 7, 2007 | 02:31 PM
atilla's Avatar
i am very jealous it took you less than 30 minutes to put yours on.
when i was replacing the perches for the bar on my car it took me almost four hours. this is mostly because every single bolt snapped and had to be drilled and re-tapped. ughhhhh.
Old Mar 7, 2007 | 02:34 PM
I'm pretty sure the folks at meant to order "rust stopper" but accidentally ordered "super rust builder plus". Every bolt under the Lancer rusts to **** about four miles after you leave the dealership.
Old Mar 7, 2007 | 03:16 PM
subydrift's Avatar
I got my bar from Summit Racing. The last one they had on sale! DIRT cheap! But mine was fast because I didn't do the perches. I am going to get those in a couple weeks.
Old Mar 9, 2007 | 06:24 AM
Shingen's Avatar
I don't know why I laughed so hard, oh wait... I recall trying to remove my exhaust. Now that wan't so funny.
Fox
Old Mar 9, 2007 | 07:42 AM
CoreyJBarron's Avatar
Fox
Yeah I remember removing my exhaust too, it was freaking gay. But only 1 bolt broke in the removing of the whole exhaust and catalytic converter so it wasnt too horrible lol
Old Mar 9, 2007 | 08:13 AM
subydrift's Avatar
Thats usually how it goes for me too. I was shocked when all the nuts broke loose without even using wd-40 or anything. We'll see... I know that because the sway bar was so easy, the perches are going to be a huge PITA.
Old Mar 9, 2007 | 08:26 AM
blaze_125's Avatar
Make it easier for your-self, and periodically apply some loose-nut on the bolts. Lube them up once or twice a day for 2-3 days before you start working on it. That way, the lube will have time to break through the rust and crap.
Is it a garanteed solution? Nope. But it can't hurt.
Old Mar 9, 2007 | 08:28 AM
wickdaddy's Avatar
you know very well that there is no rust on the bottom of my car
ya, so, 3 of the 4 of my bolts broke off... just decided to get custom perches they will be here today
Old Mar 9, 2007 | 10:10 AM
And let's not forget that both endlinks broke. And I got rust in my eye.
Regarding the rust stories, I think I have the best - when working on kfos01's car, the exhaust was 100% seized. Couldn't get the nuts/bolts off with a cutting wheel. Eventually he bought a whole exhaust, so we removed the entire stock setup in one piece (yes, everything from the header to the muffler). Finally disassembled the pieces with a blowtorch.
Old Mar 10, 2007 | 08:23 AM
subydrift's Avatar
When I had my wrx, I was putting a new downpipe on and all the nuts and bolts came pretty easy but 3 of the 5 seized up when I was threading them back on?
Never quite figured out why that happened? The threads were all good before I put them back on too.
Old Mar 10, 2007 | 08:36 AM
grubiaco's Avatar
Congrats on the swaybar. I felt the difference when I first installed it.
Old Mar 10, 2007 | 08:38 AM
subydrift's Avatar
I feel a huge difference in the handling! Now I just need to get these crappy snow tires off and some good performance tires on and then its off to the canyons!
Old Mar 10, 2007 | 11:55 AM
ROCK's Avatar
It is the single best suspension mod for the Lancer, especially the ES. Soon we will be selling the bars as sets with the autocross perches. FYI on that. THey will be packaged together. Thanks
ROAD/RACE
gotsniff
For Sale - Wheels / Tires / Suspension / Brakes
Jul 20, 2014 08:58 PM
mcgarvey
20
Sep 10, 2007 09:42 PM
AutoEuphoria
Mar 14, 2006 05:27 AM
sdhotwn
Lancer How Tos / Installations
Apr 24, 2003 02:10 PM
Tristar
13
Sep 10, 2002 03:12 PM
