Lower Control Arm/Shock Bolts - how to remove?
Old Apr 4, 2007 | 08:21 AM
rsgjr1970's Avatar
I'm unable to remove my lower control arm bolts where the rear shocks mount to it? I tried this past weekend and ended up hitting it so much with a hammer that I smashed it to the point where the nut stripped out trying to reattach it.
My rear shocks are squeking and I need to change them but now the bolts (17mm) are screwed up and I need to figure out how to get them out and find replacements.
Does anyone have any suggestions other than taking it to a shop?
Thanks in advance.
btw - 2002 Lancer OZ
Old Apr 4, 2007 | 10:17 AM
atilla's Avatar
that sucks that you messed up the threads... just keep spraying it with liquid wrench and slamming it with a hammer... it took me FOREVER to do my rear struts. pick up some new camber bolts from to replace the freshly jacked up ones. some home depot grade 8 bolts will do in a pinch as well... i drove on one that my friend and i milled down when we couldn't get a bolt right away.
Old Apr 4, 2007 | 10:28 AM
SLVROZ_03's Avatar
I was able to use my socket wrench, plus a little leg action to break those suckers loose. The factory torque on those things are ludacris!
Old Apr 4, 2007 | 10:29 AM
Blacksheepdj's Avatar
The shock is crushing the bolt into the control arm. You need to put a jack under the shock to remove that pressure. Then it'll come right out.
Old Apr 4, 2007 | 10:35 AM
wickdaddy's Avatar
or just buy a plane ticket for doug and he'll get it right out glad doug lives close... I can just call
Old Apr 4, 2007 | 10:38 AM
That works too. I haven't been down to Georgia in 10 years.
Seriously, I only know that from experience. I swapped suspension on my Lancer 3 different times, so I definitely encountered that problem. You live, you learn.
Old Apr 5, 2007 | 08:30 AM
rsgjr1970's Avatar
Thank you guys for the input. I really appreciate it. I'm going to give it another try tomorrow. It's really pi$$ing me off and became personal. Watch out...
Does anyone know where I can get the replacement bolts and nuts, because I'll probably need them for the other side.
Old Apr 5, 2007 | 08:34 AM
crypto's Avatar
Former Vendor
stealership
Old Apr 5, 2007 | 10:19 AM
Either stealership, or maybe a parts store. Those are pretty big bolts, so the average parts store probably won't carry them... unless you get a similarly sized standard bolt. Maybe look into that.
Old Apr 5, 2007 | 01:02 PM
SLVROZ_03's Avatar
Make sure the bolts are automotive grade if you go to a hardware store!
Old May 16, 2014 | 12:40 PM
novaman's Avatar
the back bolt on the control arm is spining and wont come out or wont go back in what should i do?
Old May 16, 2014 | 12:55 PM
novaman's Avatar
i am trying to remove the right front control arm and the back bolt wont come out all the way and wont go back in what should i do????????
Old Aug 25, 2020 | 10:44 AM
Bailey O'luck's Avatar
mine did the same thing till it snapped off did you fix yours if so what did you do?
N1MR0D
Jul 4, 2017 08:47 AM
slowonder
Mar 6, 2012 07:06 PM
urbanknight
37
Dec 26, 2011 01:35 PM
urbanknight
Lancer How Tos / Installations
Dec 15, 2006 12:26 AM
WRC4ever
Jan 22, 2003 12:36 PM
