Pod filter issues!
Old Apr 14, 2007 | 10:00 PM
mcurran's Avatar
Pod filter issues!
hey guys,
i just installed a pod filter and the car was running rough, so i reset the ecu , and now when i start the car it runs very rough and constantly stalls. i know it should run rough and then settle down. with the aircon on it will idle fine for a few minutes and then stall, without aircon it will stall unless i hold my foot on the accelerator. is there anything else i could try?
i took the car for a drive before i reset the ecu and the power is very uneven, the car will rev fine until about 3500rpm and then there is a deadspot in the power, and then about 4000rpm it will pick up again.
any help would be nice, i know this should be in the engine tech page but i need a quick response as i am in a hurry.
thanks
mcurran's Avatar
by the way the car is a 04 lancer vrx - manual
Old Apr 14, 2007 | 10:04 PM
ambystom01's Avatar
Try resetting the ECU again and don't touch it, let it idle for a few minutes. Could be a loose connection or a leak.
Old Apr 14, 2007 | 10:08 PM
mcurran's Avatar
thanks for the quick reply, it just wont idle if i dont leave my foot down, i'm not sure wat to do, should i just take it for a spin around the block?
Old Apr 14, 2007 | 10:09 PM
ambystom01's Avatar
I wouldn't, if it's not idling right something is obviously wrong. What other mods do you have? An intake shouldn't do this.
Old Apr 14, 2007 | 10:13 PM
mcurran's Avatar
i have only had the car for a few weeks, this is the only mod. is there any procedure when resetting the ecu? i think i read somewhere about either having or not having the aircon on. i have searched but cant find anything significant. all connections are fine, i'll go see if i can find any leaks.
Old Apr 14, 2007 | 10:15 PM
ambystom01's Avatar
All you do is remove the negative terminal from the battery, leave it for 10 minutes, hook it back up and then start the car. Did you hit the MAF or anything when installing the filter?
Old Apr 14, 2007 | 10:17 PM
coal's Avatar
Go back to stock, see if the problem persists.
Old Apr 14, 2007 | 10:18 PM
mcurran's Avatar
possibly, i had to take of the air sensor when installing the pod filter. but i was gentle, dont think i bumped it or anything. how tough are they? i tightened up the connections so there shouldn't be any leaks, i'll go give it another go. thanks
Old Apr 14, 2007 | 10:22 PM
ambystom01's Avatar
Unless you bent the honeycomb it should be fine.
Old Apr 14, 2007 | 10:43 PM
mcurran's Avatar
i just took it for a drive, it idles fine now. but between 4000rpm and 5000rpm it hesitates a bit, but hopefully after a bit of driving it should be fine. one of the little honey combs was a tiny bit bent, but it was like that when i bought the car. thanks for your help guys and if anyone has anymore info about the hesitation let me know.
Old Apr 14, 2007 | 10:47 PM
ambystom01's Avatar
I think that's normal.
Sheasta
Oct 9, 2015 12:56 PM
justboosted02
Aug 19, 2013 05:29 PM
kuvesh
13
Dec 12, 2011 09:49 AM
SilverLanEvo
Jul 5, 2011 10:52 AM
EVO(boss)
Jan 3, 2010 09:02 AM
