What is a Torque Curve???
Old Mar 20, 2002 | 11:27 PM
Pachanga's Avatar
Question What is a Torque Curve???
I've been asked what the torque curve on my OZ is??? Does anyone have a simple way of figuring that out? Also what is a torque curve? If anyone could help me out, it would be greatly appreciated. Thanks.
Old Mar 22, 2002 | 02:48 AM
Exbat's Avatar
Other Lancer owners may have dyno'ed their cars so I can't provide your numbers for you, but I'll take stab at explaining what a torque curve is...
A torque curve is simply the graphical representation of the torque vs. RPM relationship, i.e. how much torque is available at a given RPM. Large and forced induction engines typically have more torque available at lower RPM's and maintain it through the engine's range, resulting in a "flatter" torque curve. Smaller, high-reving, multi-valve engines achieve high horsepower numbers for their size but torque remains low and is acquired in a gradual, more linear fashion (think 45 degree angle vs. flat line). Your NA Lancer curve is probably very similar to that of other 16-valve 2.0 liters: Mazda Protege, Honda RSX, VW Jetta. Note that the RSX S has one more ft. lb. of torque than the base RSX, but it's only available at a lofty 6000 RPM rather than 4000 for the base model. In contrast, the turbocharged Audi/VW 1.8 liter engine in my Passat makes about 155 ft. lb. (max) of torque available from 1,800 - 4,500 RPM, as I recall. According to Mitsubishi's site, all US Lancers develop 130 ft. lbs. at 4250RPM, so I'd guess that at around 3000 RPM it's making less than 100 ft. lbs., roughly what small cars of twenty-five years ago made without 16-valve heads. What all this means is that when you floor the gas pedal at a given RPM, the torque (power) is either available to press you into your seat, or you have to watch the tach needle climb before you feel anything (or downshift). Hope this helps...
Old Mar 22, 2002 | 09:46 PM
Hot Rod's Avatar
Click to see a Torque Curve. (Red Line)
CLICK HERE
492ft/lb max @ 4500 ( pulls well)
Hope this helps
ROD
Old Mar 24, 2002 | 10:26 PM
Pachanga's Avatar
Lightbulb
Cool, thanks that definatley helped.
ridenrunwv
Sep 19, 2015 06:42 PM
Uscbryan
Sep 26, 2013 11:59 AM
smanders
20
Feb 14, 2013 01:08 PM
racer135
14
Jan 4, 2010 04:48 PM
SWOLN
Mar 31, 2008 03:09 PM
