Bodywork peoples look here
Old Sep 10, 2007 | 08:36 AM
03_Lancer_ES's Avatar
I was offroading in my car and I met with a tree branch at approx 1km/h. Little did I know it made a neat little crease in the sheetmetal of the driver's rear door. Anyone know if/how this can be fixed? I tried to do it by removing the doorpanel from the inside, but the crash bars are all in the way...What would it cost to get this fixed by a bodyshop ballpark? Is it worth it?
Attached Thumbnails Bodywork peoples look here-sunset-086.jpg   Bodywork peoples look here-sunset-087.jpg   Bodywork peoples look here-sunset-088.jpg
Old Sep 10, 2007 | 03:07 PM
eehjay's Avatar
It doesn't look too bad. Then again these are just online pictures, I'm sure it looks worse in person. A light layer of body filler and repaint should be fine, no need to pull it out. That dryice trick might work, haven't tried it out though.
Old Sep 10, 2007 | 04:02 PM
I was wondering about the dry ice trick, anyone tried it? (you're referring to the dry-ice and heat cycles?)
Old Sep 10, 2007 | 04:58 PM
eehjay's Avatar
That's what I'm talkin' about! I haven't had a dent in my car since I found out about the trick, I'll try it if it happens though. A few dudes I know said it worked, but they took it to a collision shop to do it I guess they couldn't figure it out on their own.
Old Sep 10, 2007 | 09:42 PM
Green_Bandit's Avatar
Sadly, if it would cost you over $100 I wouldn't bother. But, if you care about your car you have to do it. I'd try the ice trick myself first. I've seen it posted on the forums before...
Old Sep 11, 2007 | 06:42 AM
drucea's Avatar
I don't think dry ice works for longer dents, more for round dents that can be popped straight out. Your crease would either have to be rubbed out from the other side, covered with body filler, or replace the whole door. Try some junk yards.
Old Sep 11, 2007 | 09:57 AM
SLVROZ_03's Avatar
Yeah, dry ice won't fix that...but now that I think of it, it might fix that smaller dent O have in the trunk lid of my OZ. Thx for that comment!
Back to you...you'll need some body filler (I prefer FG filler) and respray that door.
Old Sep 23, 2007 | 03:16 PM
oLacy's Avatar
I tried dry ice for a dent on mine and it never worked.
Im sure it only works for smaller dents and wouldn't do much for your door.
