Top End
Old Aug 29, 2001 | 06:16 AM
92vr4ny's Avatar
Top End
I know the Lancer has better botton end then my car (92 3000GT VR4), but what about middle speed say the 80-120ish? I was also how it compaired to Supras?
Old Aug 29, 2001 | 09:37 AM
LanEvo's Avatar
i think evolutions are electronically limited to 120mph
Old Aug 29, 2001 | 09:42 AM
92vr4ny's Avatar
That Sucks
I am still in 3rd gear @ 120!!!! 126mph=redline
Old Aug 29, 2001 | 09:44 AM
LanEvo's Avatar
what...in GT3???
that's gonna hurt the car in RL
Old Aug 29, 2001 | 09:46 AM
All We'll Drive's Avatar
Wow, 126 in third
Old Aug 29, 2001 | 10:04 AM
92vr4ny's Avatar
Yeah
That is a 1st gen VR4, only 5sp, 2nd gen were 6sp so they have it lower, but still 100+
Old Aug 30, 2001 | 05:54 AM
tommi the tank engine's Avatar
LanEVO,
The Evo's are set to read/display speeds in kph. The speed limiter comes in when the speed reaches 180kph, which equates to 112mph.
What we do in the UK is convert the speed signal to mph from the sensor and feed it to the ECU. This fools the ECU into thinking it is seeing a slower kph speed, infact its mph. This means the speed limiter never operates, as the car wont reach 180 mph!
So I can be driving my E6 at 130mph (on a track of course) and the ECU sees the speed as 130kph, below the speed limit.
The only other thing we do is put a label over the kph on the speedo that reads mph. The speedo is still accurate.
Hope this helps.
Old Aug 30, 2001 | 09:30 AM
EVO7's Avatar
All u have to do is take the speed limiter off, or get a new ECU
Old Aug 30, 2001 | 12:32 PM
Evo7, the speed limiter is internal to the ECU, which is why you need to feed the speed signal to the ECU by some electronics to fool it. You cant just 'remove it'. I think buying a new ECU just to remove the speed limiter is a very expensive option.
Old Aug 30, 2001 | 02:44 PM
LanEvo's Avatar
Originally posted by tommi the tank engine
LanEVO,
Hope this helps.
so what u do in UK does that apply to the evos coming straight from the dealers or do owners do stuff to it
Old Aug 30, 2001 | 06:15 PM
EVO7's Avatar
it will cost about 400 bucks around there, for a new ECU ill pay that, im not gonna have a damn evo and only have it pullin 112 MPH...
Old Aug 31, 2001 | 03:47 AM
LanEvo: All the imports (Evo, Impreza, Skyline etc) coming to the UK need the speedo converting from kph to mph as part of the SVA test (amongst other things). The easy way of doing this is what i have described previously. All this would be undertaken by the supplying dealer. The converters arent expensive (I'm guessing at less than 100ukpounds fitted) and are certainly cheaper than a new ECU. The other benefit is the speed limiter is moved to 180mph. Incidently the 'UK' cars supplied by Ralliart needed this modification too.
Having said all that is the 112mph limit a problem? The Evo is not a high speed car, its greatness comes from its handling and fast acceleration. If I wanted to drive in excess of 112mph there are many more better suited cars.
Old Aug 31, 2001 | 04:38 AM
LanEvo's Avatar
okay...now the image is clear
tommi, how fast can an evo go bone stock w/o the limiter? (top spd)
Old Aug 31, 2001 | 05:56 AM
I'm guessing that you should be able to achieve 140mph. I seem to remember seeing 120mph in my scoob on track once or twice and that had about 80bhp less than the Evo. Dont know how accurate the speedo was though.
Old Aug 31, 2001 | 11:23 PM
Sabotage's Avatar
Sooo..
How good dose it pull 30mph to 70mph, 60mph to 100mph?
