Mitsu Oil Filters
Old Jul 15, 2008 | 09:06 AM
EdT's Avatar
EdT
Mitsu Oil Filters
Anyone knows who makes them for Mitsu ? Denso, Champion, Purolator, Wix ???
Looking to stock up some, but don't to pay dealer prices !
Old Jul 15, 2008 | 04:29 PM
cRc`22's Avatar
they are $3 at my dealership..
Old Jul 15, 2008 | 04:33 PM
Mitsutech56's Avatar
Buy them by the case on eBay or at the dealer. part # MZ690116
Don't forget the drain plug crush washers.
Old Jul 15, 2008 | 05:05 PM
Walkingchaos's Avatar
why do you want OEM filters ? go with KN or Mobile 1 or something along those lines.
Old Jul 15, 2008 | 08:05 PM
EdT's Avatar
EdT
Really, you are lucky, here in Canada they are around $8. Are those really Diamond star filters or some other brands ?
Would you buy me a case ?
I have been reading up on oil filters and apparently not all filters are made the same way.
The big names like Fram, Quaker State and Pennoil are supposely all made by Champion Labs and are crap with cardboard ends and glued filters.
http://www.knizefamily.net/minimopar...ers/index.html
http://www.knizefamily.net/minimopar.../opinions.html
Old Jul 16, 2008 | 06:38 PM
EdT's Avatar
EdT
Ok, finally took the Mitsu OEM filter off and to my surprise it is a Denso as it is written on it and it has the Denso O-Ring seal !, but it is made in Thailand which leads me to believe that Denso has contracted out their oil filters to FULL(Siam Filter Products).
Old Jul 16, 2008 | 06:44 PM
lancer2show's Avatar
i was told a different size in oil filters can change oil pressure as well.
Old Jul 16, 2008 | 07:21 PM
Nathan0490's Avatar
I have an AMSOIL filter on my lancer, much better then the stock filters...
Old Jul 16, 2008 | 07:53 PM
EdT's Avatar
EdT
You think ?, I don't think so !
Clarcor vs Denso ...is about equal, Denso has more filtering surfaces so it wins hands down in my book !
Old Jul 16, 2008 | 09:34 PM
Ramen_Noodle's Avatar
I use AMSoil filters, oil, and fuel additives (for now, atleast until I need other AMSoil products). Needless to say, I am very impressed with the quality of the products and will continue to use them. Although I do need to get my hands on a new air filter.
Old Jul 17, 2008 | 12:42 AM
Lumpy's Avatar
Pure One Purolators have worked fine for me. 112,000 miles and counting.
Old Jul 17, 2008 | 10:08 AM
EdT's Avatar
EdT
I was not able to use my filter socket to remove the canister since the wall of the oil pan is too close to the filter, I had to drive a screwdriver through it to turn it loose. This is a dumb Mitsu design in my books !
What kind of filter wrench does Mitsu dealers use ?
Old Jul 17, 2008 | 06:46 PM
if its that tight on youre cranking it down to hard when you change your oil. you dont need 1000 pounds of force on an oil filter. and is ANYONE using mobile 1 or K&N ?
Old Jul 17, 2008 | 09:45 PM
EdT's Avatar
EdT
The dealer changed the filter last time and in any case even hand tight with 3/4 turn becomes pretty tight to remove.
Mobil 1 and K&N filters are made by Champion Labs, in my opinion not worth the money and dirty oil is proned to leak back in the filtered passage due to weak valve designs.
