swap 4g18 to 4g63t evo 5 done
Old Jun 1, 2009 | 10:07 AM
  #31
Juan Martinez's Avatar
Originally Posted by lancer1.6
1.i lost all the pics for the build..i'll post some more pics for the car soon..
2.the wiring wasnt hard.it can be done in the same day...the only problem is we couldnt get the airbag to work..the light is always on.
3.yes i did..i took the whole thing actually from an evo.hubs,spindles.rotors and calipers they were all connected.and they fit right on (no mods needed) even if u are keeping the lancer coil overs.
but i am having this problem now..i got the front wheel bolt pattern 5x114.3
and the rear is 4x100..
still looking for a solution for the rear hubs..i wanna make them 5 bolts as well
i dont know if any one got any ideas..
I can think of two options.
1. Get the rear hubs, backing plates, ebrake, calipers, rotors, ebrake anc cables off of a ralliart
2. Get a set of rear hubs and drum brake cover off of an outlander. You just put the hub on and then the drum cover. no need to do a rear disc brake conversion.
Old Jun 1, 2009 | 12:28 PM
  #32
lancer1.6's Avatar
i guess 2nd option wud be much cheaper.i'll try to find the hubs for the outlander..thx for the hint man.
Old Jun 1, 2009 | 01:55 PM
  #33
Don't forget the drum cover. If you find a good deal, let me know, I plan on doing the same soon.
Old Jun 1, 2009 | 02:08 PM
  #34
turbotime's Avatar
can you go into a bit more detail about the outlander way? When I got the outlander rear subframe for mine it came with drums.. could you clarify what do I need to do to swap to disc?
thanks man
Old Jun 1, 2009 | 09:59 PM
  #35
thanks man
Ok, here is what I know you need.
Backing plates
E brake
E brake cables
Calipers
Caliper bolts
rotors
pads
brake lines
Hubs if you don't have them or don't want to swap
Here is a similar conversion on an eclipse. The hubs are completely different and he did some modding to reuse his e brake cables. I don't recommend that, just get new ones. http://www.rcaz.com/rcaz/sub%20index...disc/index.htm
Here is another link http://www.4g64.150m.com/rearbrakeconv.html
Old Jun 2, 2009 | 06:34 AM
  #36
turbotime's Avatar
perfect... thanks man..
Old Jun 2, 2009 | 08:31 AM
  #37
Back on topic, did you convert the transfer case to FWD?
Old Jun 2, 2009 | 07:47 PM
  #38
lancer1.6's Avatar
yes man i did..the LSD in the transfer case has been replaced with a Quaife FWD LSD
and we took off the transfer case's tail off as well..a custom plate was placed instead.
Old Jun 8, 2009 | 09:21 AM
  #39
lancer1.6's Avatar
my car seem to bee so aggressive that i feel its not a street car any more..i think its because the solid mount i am using at the back of the tranny..and i had to customize the pracket mount as well.it doesnt feel right(am using the base lancer subframe).(the stockmount made the transfercase hit somewhere every time i shift.
what am trying to find out..in order to change the subframe to evo's do i have to take off the engine and tranny..?
or it can be done from the bottom..
Old Jun 8, 2009 | 11:44 AM
  #40
You should be able to do it from the bottom without taking out the engine and transmission.
Old Jun 9, 2009 | 05:03 AM
  #41
lancer1.6's Avatar
thats good..pockets are empty ..am gonna try to find a good deal to get it done
thx man
Old Jun 9, 2009 | 03:24 PM
  #42
thx man
there was an evo subframe on ebay awhile back for like $200.
Old Jun 10, 2009 | 06:59 AM
  #43
lancer1.6's Avatar
check ur private msgs
thanks for helping me out man..
Old Jun 10, 2009 | 10:05 AM
  #44
Your welcome, check your box.
Old Jun 18, 2009 | 06:48 AM
  #45
lancer1.6's Avatar
i got some more photos..my friend doenst know how to take pics (am out of the country).
why the heck i wud wanna c the tire...
u can see i have 2 different rims..2 different bolt patterns
the actuator is hitting the fan, and its hitting the radiator in motion .. it needs a single fan...
Attached Thumbnails swap 4g18 to 4g63t evo 5 done-img00016-20090618-0949.jpg   swap 4g18 to 4g63t evo 5 done-img00019-20090618-0949.jpg   swap 4g18 to 4g63t evo 5 done-img00021-20090618-0950.jpg   swap 4g18 to 4g63t evo 5 done-img00024-20090618-0951-1-.jpg   swap 4g18 to 4g63t evo 5 done-img00031-20090618-0955.jpg
