checkup
Old Sep 22, 2008 | 10:49 AM
lancerguy0208's Avatar
checkup
Hi. My '02 Lancer OZ currently has 73K miles on it, and I was wondering if there is a 75K mile checkup, tune-up, etc. required. I bought the car used and it didnt come with an owner's manual. If anyone could let me know I would appreciate it. Thanks.
Old Sep 22, 2008 | 02:14 PM
ThunderOZ's Avatar
Have you changed your timing belt/water pump?
Old Sep 23, 2008 | 11:37 AM
I haven't changed anything on the car. I've only put a couple hundred miles on it since I bought it. All I did was inspect the brakes to be safe, and then change the oil. But other than that I need to know what maintenance I need to start planning for.
Old Sep 23, 2008 | 11:47 AM
bcollinstex's Avatar
timing belt, water pump.
spark plugs, maybe plug wires and coils.
Coolant flush.
Clutch.
Check springs, and bushings
Check and replace vacuum hoses
Check brakes, rotors, calipers, drums, brake booster, master cylinder
tires, alignment, balance
Those are the most important to do.
You'd also want to have your AC system checked out.
Old Sep 25, 2008 | 04:12 PM
thanks
razorlab
E85 / Ethanol
115
Sep 14, 2019 12:28 PM
TurkEVO9
May 31, 2011 06:12 PM
cmbjive
Jul 19, 2007 05:53 PM
USMCEVO
10
Feb 27, 2007 03:44 PM
