evo 8 turbo on lancer
Old Dec 8, 2008 | 07:12 AM
def1's Avatar
Im getting rid of my turbo and intercooler piping so Im wondering if its possible to fit it onto a lancer. My friend would be happy as hell to get this turbo from me haha so Im just wondering if its possible. Im sure it could only run like 3-4 pounds of boost but still it would be a fun project. Let me know guys if you have tried it and if it works.
Old Dec 8, 2008 | 07:41 AM
bcollinstex's Avatar
Yes. There have been several build thread for an EVO 8 16g.
Search this section.
https://www.evolutionm.net/forums/lancer-aftermarket-forced-induction-tech-57/
However, every one has had to do custom fab work, because there isn't a bolt on kit like RRM's for this particular turbo.
Old Dec 8, 2008 | 07:49 AM
def1's Avatar
thanks. custom fab wouldnt be too expensive. ill let my friend know
Old Dec 8, 2008 | 10:42 AM
ThunderOZ's Avatar
Yea it works fine. I have one with an evo manifold that has a lancer flange on it, and I'm also using the evo downpipe.
Old Dec 8, 2008 | 11:12 AM
kemoly's Avatar
yes very posible becarefull with the boost!
Old Dec 8, 2008 | 11:28 AM
def1's Avatar
so from what i can tell only the upper ic pipes and the downpipe have to be custom fabricated. That should be pretty easy. How much boost do you think is possible without head work
Old Dec 8, 2008 | 11:38 AM
ThunderOZ's Avatar
No, all the intercooler pipes, intercooler, and downpipe fit great. The downpipe is a little longer than the stock lancer downpipe though. So he'll either need to get it cut, or just get the rest of the exhaust redone. If he has enough fuel and proper tuning, 10 psi would be ok, at max. Generally, the safe zone is between 7-10 psi.
Old Dec 8, 2008 | 11:39 AM
ThunderOZ's Avatar
Oh and on the turbo, he'll have to grind that little bracket that the oil line has a support bolt going into.
Old Dec 8, 2008 | 06:37 PM
def1's Avatar
thanks. well then this project will be even cheaper than i thought.
