need help with exaust questions
Old Sep 22, 2003 | 01:45 PM
Mag5kl's Avatar
ok i plan to get a RMR intake along with a new exaust, i plan to get two carsound 2.25 hight flow catalytic conveters, 2.25 pipe and heres the thing my friend is going to give me his magna flows but takes a 3 inch pipe, so heres my question is there an adapter for this and if so will i still get back pressure? is this a bad set up?
Old Sep 22, 2003 | 01:56 PM
majestic lancer's Avatar
someone correct me if im wrong, but 3 inch piping is usually used for turbo setups. us NA people usually use just 2.25 or 2.5 piping. im not an 'engine tech' but i do believe that you will lose some low-end power because of the back pressure lost..
Old Sep 22, 2003 | 02:01 PM
Mag5kl's Avatar
i want to know if theres a 2.25 pipe to a 3inch so i can attach the 2.25 pipe into the 3inch muffler, and if its a bad set up
Old Sep 22, 2003 | 02:02 PM
DRC Imports's Avatar
That will be very bad for a NA Lancer. You want MAX 2.5"
3" will kill you until you get to like 3rd gear at 4500 RPM (just a guess)
Old Sep 22, 2003 | 02:07 PM
illizit's Avatar
no, it will be fine he says he's getting a 2.25" exhaust all the way till the high flow which he will make an adapter to fit to the 3 inch then out the other end as 2.25" again. So its perfectly fine to me.
ie:
===2.25"===[HIGH FLOW]====[Muffler]==[TIP]
^3"inch adapter
lol something like that
Old Sep 22, 2003 | 02:11 PM
Ah , maybe I should read better. That doesn't sound all too bad. I thought you were doing a 3" with 2.25" cats. I am just wondering what kinda adaptor you could use ??
Old Sep 22, 2003 | 02:18 PM
illizit's Avatar
im sure any muffler shop could do it right? I dunno..
Old Sep 22, 2003 | 02:19 PM
Mag5kl's Avatar
====2.25===highflow======muffler==tip
...............................................3in ch adapter
nevermind the periods i had to add those in for the diagram to work right thanks for helping guys!
Old Sep 22, 2003 | 02:28 PM
TURBOit's Avatar
yea man go to a muffler shop, they'll weld, probably better than a makeshift adapter, won't be expensive either, setup looks fine
p.s. i don't even think its wise for a turboed lancer to go 3", no one is really pushing high enough horsepower to make any worthy gains, except maybe boe.
Old Sep 22, 2003 | 03:15 PM
JWERNER24's Avatar
In Timeout
get it welded, dont mess around with ghetto adaptors.
Old Sep 22, 2003 | 06:02 PM
fkrzo's Avatar
For like $5 you can get an adapter at most any autopart store, and be ready for a real raspy sound. But all in all it should be pretty good along the power lines.
