Has anyone had problems with Sparco Gril Series Pedals?
Old Sep 25, 2003 | 11:03 PM
imapunkclaimer's Avatar
I tried installing these, but they need to be drilled. i drilled but i cant mount them in the middle of the pedal because on the clutch and brake theres the bar that comes down so i have to move it off to the side then i moveed it to the right of the brake bar and it gets caught on my shoe whenever i lift off the gas. I dont mind the clutch being out there, but what did you guys do with the brake and gas?
Attached Thumbnails Has anyone had problems with Sparco Gril Series Pedals?-sparco-pedals.jpg
Old Sep 25, 2003 | 11:23 PM
drummerjun's Avatar
Got those and No prb at all...
Old Sep 25, 2003 | 11:26 PM
what did you do about the whole bar thing? did you offset it?
Old Sep 25, 2003 | 11:29 PM
drummerjun's Avatar
hehe...to be honest, I had them installed by some guys at the body shop when I brought my friend to get his bumper repaired....
Old Sep 25, 2003 | 11:54 PM
damnit i dunno im just gonna keep drilling till i either get it right or i totally break the metal
Old Sep 25, 2003 | 11:58 PM
ronsozlancer's Avatar
Its easy bro. Just check the back before you drill. The brake pedal has the bar in the back so make the top hole first. Drill a pilot hole ( small hole with a small drill bit) a little bit to the left of the bar. Then just make sure that theres enough room for the nut to be screwes in when you make the hole bigger. Thats it for the brake cuz the bottom hole should just fit perfect without touching the bar on the back. For the gas you could just take it off to work with it more easily. Center the oem gas pedal with the sparco and drill the holes making sure that the back notches dont mess up ( the ones that hold the pedal) then what i just did is zip tie them bastards cuz the bolts didnt reach. Thas it! Sorry bro if this is kind of complicated but hope it is of use to you. Good Luck
Old Sep 25, 2003 | 11:59 PM
no i got it, ill redrill tomorrow. thanks
cts4g63
Jan 6, 2016 02:22 PM
bryan0
Jan 9, 2010 09:27 AM
tuffguy
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 17, 2005 08:23 AM
vtluu
Dec 7, 2003 07:57 PM
jknasins
12
Oct 6, 2003 11:21 PM
