O2 Sensor help please!
Old Aug 12, 2009 | 04:52 PM
Fuze49's Avatar
I keep getting a p0137 error. I have replaced the o2 sensor and I know the wiring is correct (or should be) and I have no idea whats going on. First it was a p0131 error and now its a p0137. Any help would be greatly appreciated.
P.S. - I did search.
Edit - Upon a double check, the p0131 error is back as well.
Old Aug 13, 2009 | 01:32 PM
Fuze49's Avatar
Any ideas? I know some one on here has had to have dealt with this issue before.
Old Aug 13, 2009 | 07:16 PM
Daedalus2051's Avatar
after a quick search on google for those DTCs i found this page and a generic definition for both PO codes:
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor 1)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
seeing as how both circuits have low voltage i would think that it's not a fault of the sensors themselves (how often would you see BOTH sensors fail at the same time?) but rather either a rich or lean condition in the engine. meaning that the engine isn't getting the correct amounts of air and/or fuel.
that's my 2 cents on what it could be. have you been noticing any loss in power or gas mileage as of late? any mods recently installed that might be the culprit?
Old Aug 14, 2009 | 11:44 AM
Fuze49's Avatar
I replaced my fuses and the codes went away. Havent had a CEL for 145 miles now.
No new mods in a long time.
Old Aug 14, 2009 | 05:30 PM
fuses? thats an odd fix for those codes lol... which fuses did you replace?
Old Aug 14, 2009 | 06:00 PM
Fuze49's Avatar
It was the engine fuse. I pulled it out and it was completely fried.
Old Aug 17, 2009 | 12:07 AM
hmmm well don't forget to figure out why it blew out in the first place
Old Aug 19, 2009 | 08:56 PM
mines hotter's Avatar
hmm yea thats weird my car had a po144 code its for the 3rd o2 alot of cars are having a problem with the 02 sensors i reset my code like a dummy but its nun too serious these 08's sure do have alot of problems the pullin to the left pulley failure gas gauge malfunction n now the o2 sensors whats nexdttt
babaz7
May 22, 2016 09:57 AM
AJsGenerX
May 8, 2012 05:54 AM
smokehim98
Jan 18, 2012 09:47 AM
newbienco
Jun 27, 2010 09:31 AM
BluesunsXIV
Jun 27, 2009 06:34 AM
